V70 rotors need the lug holes opened up. I use a 3/4" bit I got at Home Depot for like $15.
Im a cheap ass mofo, but money well spent when it takes 5min for both instead of 5min per hole.
Ive not used them on alum upright, but steel needs 2 spots ground down a little to clear.
The upper corner area at the top to clear the inside edge of the rotor, and a raised area toward the bottom to clear the rear face.
I have always had to knock the outer pins in the caliper that the pads sit on down about 1/16".
Some say they didnt have to do this. Can be a little tricky to get at because of where they are inside the caliper.
Ive attacked them with all sorts of stuff and one of these would be well worth the $25 if they are hitting.
http://www.harborfreight.com/38-in-b...der-60627.html
