Results 1 to 14 of 14
    Jun 03 2015
    Syracuse, NY
    S6 4.2l Oil Pan gasket, what sealant/procedure.
    Looking to replace the oil pan sealant when doing the next oil change.
    Is there a specific sealant Audi uses or recommends?
    Is the procedure simply unbolt and leave the sensor attached to the pan and work around it?
    Wish fel-pro made a gasket for it...
    Veteran Member Four Rings G Men 08's Avatar
    Feb 05 2008
    One trick pony at the time.
    Waterloo NY
    This stuff works great. https://www.ecstuning.com/Audi-All_R..._Pan/ES263904/
    Just make sure you let it cure for a few minutes before you reinstall pan. And follow torque specs as per bentley manual. As for the sensor, just unplug it and you can leave it in the pan.
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    B5 S4 A few mods-SOLD thankfully!!
    MKIV Golf TDI- SOLD MPG were amazing but other than that...
    C5 allroad 2.7 auto
    Jun 03 2015
    Syracuse, NY
    Is there any reputable manufacturers of an actual gasket, be it cork, silicone already cured, or something of the sort?
    This is the only actual gasket I found, I believe.
    http://www.jimellisaudiparts.com/pro...wd=&origin=pla
    Anyone have the torque specs for the bolts? I traded my bentley manual back in as I recieved my $90 back..
    Feb 05 2008
    Waterloo NY
    Number 81 in that diagram is the gasket material listed. I believe the gasket you are referring to is the valley pan gasket.
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    C5 allroad 2.7 auto
    Jun 03 2015
    Syracuse, NY
    You are correct, I am in need of the sealant labeled "81".
    Guess I find it hard to believe manufacturers prefer something like that which is more probable to leak if not torqued properly and waited for cure time. I'd assume it saves product cost and no new to outsource a manufacturer for that gasket.
    Do you have the torque spec, or image of the bentley procedure?
    Feb 05 2008
    Waterloo NY
    Tightening torque 10nm. I've always tightened from the center, outward in a criss crossing pattern.
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    C5 allroad 2.7 auto
    Veteran Member Three Rings carmudgeon's Avatar
    Oct 23 2012
    1995.5 S6 Avant
    Kansas City
    And speaking from prior experience, you'll be tempted to over tighten it since 10nm isn't much; don't.
    Previous vehicles: 2012 TTS Roadster - 2017 Golf R - 2002 S6 Avant - 2013 S4 - 2008 Subaru STi - 2007 Mazdaspeed3
    Feb 05 2008
    Waterloo NY
    ^what he said
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    C5 allroad 2.7 auto
    Jun 03 2015
    Syracuse, NY
    That has been my issue with RTV like sealants... have another 1500 miles or so before doing this, so we shall see how it goes.
    Feb 05 2008
    Waterloo NY
    Should be fine. I've used it on my previous 3 Audi vehicles as well as my Volkswagen and haven't had an issue. It is imperative that you remove all of the old gasket material. PITA for sure but needs to be done thoroughly
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    C5 allroad 2.7 auto
    Jun 10 2013
    United States
    Permatex RightStuff Grey is very good.
    Jun 03 2015
    Syracuse, NY
    What temperature does oil reach within a hot engine?
    Jun 10 2013
    United States
    It should be around 200 in generally. Maybe 240 if you are working the motor (not an expert here). 260+ I would start to get concerened
    Jun 03 2015
    Syracuse, NY
    Derp...
