Results 1 to 19 of 19
    Junior Member Two Rings
    Jan 16 2016
    Why do my wheels spin when turning into my driveway?
    I just picked up a 2015 S4 2 weeks ago. Love it so far, but there are still some things I need to learn about it.
    This is one that is perplexing me...
    I have a short driveway, but the angle of the tip of it is somewhat steep for a few feet, before it flattens out. On my old car, I sometimes used to scrape the bottom if I pulled in or out straight on. My prior car was a Honda Accord, and I used to pull in on an a sharp angle which seemed to prevent the bottom from scraping.
    Needless to say, I definitely don't want to scrape the bottom of my S4, so I'm experimenting with different ways of pulling in. For some reason, when I do a sharp angle turn into the driveway, I find my wheels start spinning and the only way to get up the driveway is with the momentum of the car itself.
    I haven't had someone look from the outside yet, but what I suspect is happening is that when I turn right, into the driveway, the front left wheel is off the ground for a moment. I don't understand though why the car could get stuck in this position, especially since it's AWD. I believe my car has the sport differential. Could that have anything to do with it? Last night I actually had to pull all the way back out and make a second attempt in to get up the incline.
    It's a MT, if that makes any difference...
    Thanks for any help..
    W
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Is there any snow or ice on your driveway? What tires are on the car? Do you have any pictures of it so we can get a better idea what is going on?
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Jan 16 2016
    There's no snow. The tires are Dunlop All Weather performance tires, and pretty new. I don't know the exact tire off hand. I'll try to take some pics tonight.
    Veteran Member Four Rings Johnnycash's Avatar
    Jul 31 2014
    2015 Hyundai Genesis. 1995 impala ss
    Mpls, Mn.
    pics would help.
    2011 QGM w/black optics, EPL stg1, HRE p43sc w/pss, b-12pro-kit, 034 trans mount, cts intake, stoptech drilled/slotted, akebonos all around, vmr 710 w/nokian r2s, stock rotor wheels w michelin as3+, autostyle custom floormats, 3m paint protection on entire front.
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    3 wheeling when youre pulling in on an angle (1 wheel off ground). It's worst when you have Coilovers too.
    That's why
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Aug 03 2014
    Queens
    It sucks, it spins, once you get traction... Snap. 6mt it takes a bit of finesse to overcome those angle pull in/out
    Previous
    Jun 11 2011
    Interesting. The only way for this to make sense is that the S4 is mostly FWD at slow speed. With no LSD at the front, it'll just spin the airborn left wheel.
    Aug 03 2014
    Queens
    It's usually the rear wheel that lifts off the ground
    Previous
    Jan 07 2011
    2013 C300 4Matic
    happens to me almost all the time when I go up at an angle
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Jan 16 2016
    Thanks everyone. I'll have to read more about this I guess...looks like it's a known/common "issue". I had thought since it is AWD this could not be possible. I still don't completely understand what's going on. I will have to experiment with pulling in a bit more straight on, but then I run the risk of scraping the bottom of the front bumper.
    Oct 14 2012
    Empty...for now...
    SE PA
    I have a similar driveway situation and it happens to me when I turn in from the right side but not from the left. I am lowered on coilovers and have a bunch of chassis stiffening aftermarket parts installed (drivetrain stabilizer, front strut brace, front and rear swaybars), and my guess is that the steep transition, steering angle and chassis stiffness is resulting in one tire losing adequate traction with the pavement.
    SOLD 2015 Daytona Gray S4
    Veteran Member Four Rings superswiss's Avatar
    Jan 07 2013
    San Francisco Bay Area, CA
    Yep happens on these cars. Both front and rear diffs are open and it takes EDL a moment to realize it needs to slow down the airborne wheel to get the car moving. With the sport diff it's better if one of the rear wheels is airborne, but EDL still needs to engage.
    2019 AMG C63CS, obsidian blk, blk leather w/ yellow stitching, aero pkg, CF pkg I+II, 19/20 wheels, lighting pkg, multimedia pkg, heat&vent seats, AMG perf seats, digital cluster, night pkg, parking assist, driver assist, european delivery
    2013 panther blk RS5, Ti pkg, blk leather/alcantara, nav pkg, sport exhaust, driver assist pkg, rear shade, alu kreuz, ECS spacers 15f/10r, ECS tru-float rotors, ECS brake lines, Hawk HPS pads, european delivery (sold)
    Feb 25 2014
    Texas
    Same thing happens to me when I pull into my driveway at an angle to avoid scraping. It's just the slope mixed with the angle, I wouldn't sweat it.
    Mickey (AKA: AudiS4B8)
    Instagram: ze_nardo6
    10.65 @ 129mph
    Apr 04 2012
    MSP
    You may also want to look at curb ramps - they are great!
    http://www.bridjit.com/
    Jan 28 2015
    Pnw
    Gets worse with sway bar upgrades. Chassis is stiff.
    Nov 23 2014
    North Carolina
    odd. I have a really steep drive and have no yet run into this, also a 6mt with sport diff and sways.
    2021 Glacier White S5 Prestige Coupe - ECS Swaybars, 034 dynamic+ links, ECS tower brace, wheel spacers 12.5f 15r, CTS catted Downpipe, Wagner Intercooler, Andy_FL CF inlet pipe, EPL stage 2 E40 or 034 stage 2 E85 depending on mood
    2019 X3 M40i - Sold
    2015 Sepang S4 Prestige 6MT - sold
    Oct 20 2008
    Bloomfield Hills, MI
    From what I understand, the front is an open differential and the center (front/rear split) is a torsen diff being 6MT.
    Torsen can only transfer power from front to rear if the slipping wheel/axle has some load on it. For your instance, if one front gets up in the air, the other front wheel will not gain any power, as it's an open diff. The torsen will not transfer any power to the rear because the torsen acts a a torque multiplier, of the low traction wheel. Whatever torque it senses on the low traction side, it transfers to the other side. If torque is zero (in the air), there's no transfer.
    Two ways to solve it is 1. Stab the brakes while accelerating to brake the spinning wheel in the air, causing torque and allowing the system to tranfer power to the rear, or 2. keep traction control on, which should brake the wheel in the air individually, sending power to the rear. If neither works, you need to simply carry momentum.
    E90 M3 6MT - Melbourne Red
    (Sold) 2013 S4 - Glacier White / Black
    Oct 20 2008
    Also, from what I remember, the crown diff (used only in DSG 8.5 S4's), can send power to the traction side, even if one side has zero traction.
    Jan 07 2013
    Quote Originally Posted by anerbe View Post
    Yes, that's correct. The crown diff is self locking and can transfer torque to either axle without traction control needing to brake individual wheels. My B7 S4 (torsen center diff) struggled mightily with situations like this. If I stopped with one wheel in the air it was quite embarrassing to get moving again. The drivetrain made all kinds of noises as traction control tried to reign in the spinning wheel(s) to get the car up the incline. The RS5 with the crown gear handles this much better. There's still some minor wheel slippage, but the center diff pretty much immediately locks and directs the majority of the torque to the axle with traction.
