    Sep 30 2009
    b
    n/a
    n/a
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    Worth a read.. Have you tried re-bedding? Are they installed correctly?
    Ha ha, you will see the same link posted below.
    Senior Member Three Rings Mat@1975's Avatar
    Jun 14 2015
    FRANCE
    Just seeing who has a stock brake configuration with issues with warped rotors?
    Hello,
    I suggest you this verry Good article where a lots of things are explained:
    http://www.stoptech.com/technical-su...nd-other-myths
    BR
    Mat
    S4 B8.5 AVANT | S-Tronic | Full ADS | Sport Diff | Glacier White
    MRC Stage 2 Tune | MRC TCU Tune | AMS/Alpha Cooler| AWE + AFE filter intake with airbox hole
    KW HAS Springs | H&R Sway bar F&R | Custom 14 mm Front and (13 R / 16 L) mm Rear Spacers | CR-15 Strut Brace
    OEM Rotors | Michelin PSS 255/35/19
    Q5 calipers | Goodridge SS Lines | 2-pieces Girodisc Rotors Front & Rear
    Veteran Member Four Rings ENVē's Avatar
    Nov 04 2010
    I tracked my S4 and drove it hard every damn day. Never a warped rotor.
    500AWHP/500AWTQ
    @Driven_Not_Hidden
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Audi's
    Branford, CT
    Quote Originally Posted by Mat@1975 View Post
    Hello,
    BR
    Mat
    Great recommendation. We reference this link quite often.
