I took my car into the dealer for its annual service and the mechanic said engine looked great but he had a few recommendations:
- advise replace right side charge air cooler and hose to turbo (right side charge air cooler is leaking)
- advise replace vacuum pump and cam chain cover gasket (vacuum pump and cam chain cover are leaking)
(copied from the printed report)
When i asked about fixing it and the severity, his answer was "its up to you" then took off... so i thought you guys might be able to give me a better idea of the problem and how to go about fixing it and how soon i should do that. Thanks
