Results 1 to 13 of 13
Thread: Wheel fitment
    Veteran Member Four Rings c@@kieMonsta's Avatar
    May 17 2009
    Idaho
    Wheel fitment
    Happy Super Bowl everyone! Anyways, spied some 19's being sold locally that I'm going to take a look at tomorrow. I understand that the center bore of the C7 is bigger so at minimum I'll be needing hub centric rings. My understanding is that the bolt pattern on the C7 is the same, 5x112. The wheels have a 45 mm offset. The ones on my car right now have a 48mm offset, so what does that mean in terms of how things will look visually, etc? Anyways, all info is greatly appreciated!
    Wheels in question.
    http://boise.craigslist.org/wto/5425319830.html
    Current:
    2019 Ford Expedition
    2009 3.0T A6 Avant w/Prestige package, Side Assist, and Cold Weather package
    2016 2.7 EcoBoost Ford F-150 XLT SCREW
    2007 3.2 A4 Deep Sea Blue Avant
    2006 A6 Arctic White Avant
    2002 1.8t A4 Sedan
    Veteran Member Four Rings Dutch_A6's Avatar
    Aug 19 2012
    GMC Terrain
    Belleville, IL
    Means that the wheel will be pushed out 3mm further
    Sent from my VS985 4G using Tapatalk
    Black 2012 A7 Prestige
    Zito ZF01 wheels
    EPL stage 2 tune
    Tinted marker lights
    Roc Euro intake
    AWE touring exhaust
    APR CPS
    May 17 2009
    Idaho
    Quote Originally Posted by Dutch_A6 View Post
    Thanks Dutch! Besides, that I shouldn't have any issues in terms of fitment aside from needing the adapters correct?
    Current:
    2002 1.8t A4 Sedan
    Aug 19 2012
    GMC Terrain
    Belleville, IL
    Outside of the hub centric rings you shouldn't need anything, your eyes won't notice 3mm, that's such a small change.
    Zito ZF01 wheels
    EPL stage 2 tune
    Roc Euro intake
    AWE touring exhaust
    APR CPS
    May 17 2009
    Idaho
    Thanks for the quick reply Dutch.
    Current:
    2002 1.8t A4 Sedan
    Aug 19 2012
    GMC Terrain
    Belleville, IL
    Quite welcome, good luck on the new pealers
    Zito ZF01 wheels
    EPL stage 2 tune
    Roc Euro intake
    AWE touring exhaust
    APR CPS
    Jan 30 2014
    1st gen Q45s
    FL, USA
    to OP: if you plan on mounting those directly (with the same tires), note that you are 1.2" taller than stock! that might rub, even if pushed out that 3mm (about 1/8")....
    May 17 2009
    Idaho
    Quote Originally Posted by FL C6 Avant View Post
    Anyone else think they'll rub?
    Current:
    2002 1.8t A4 Sedan
    Senior Member Two Rings se.farrell's Avatar
    Jan 10 2014
    Los Angeles, CA
    Couldn't see the listing because it was taken off craigslist. But, note what tires are on there, different tire brands actually size slightly different. I now rub under load with my MPSS that are the same size as my previous tires (conti i think?).
    Current:
    C7 A6 3.0T Prestige - Glacier White
    STAGE 1 | TSW
    C6 A6 S-line - GONE
    May 17 2009
    Idaho
    They are 255 40 19 Eagle LS2 gooodyears.
    Current:
    2002 1.8t A4 Sedan
    Jul 17 2011
    Sin City, USA
    c@@kie - I dont think you will rub considering the offset is still pretty shallow. Granted, the tires are 1.2 inches taller overall, but that will only translate into .6 inches taller from center hub to outer tire. The 255/40 is pretty meaty (sidewall width). I would look at dropping to 255/35 when if/when you get new tires.
    '09 C6.5 A6
    May 17 2009
    Idaho
    Thanks sin. That's the plan. Since the tires still have 6/32 left, I'll use them up for the time being.
    Current:
    2002 1.8t A4 Sedan
    May 17 2009
    Idaho
    Quote Originally Posted by se.farrell View Post
    This is what they look like on a C7.
    Current:
    2002 1.8t A4 Sedan
