Results 1 to 3 of 3
    Veteran Member Three Rings Senseless's Avatar
    Aug 11 2015
    Phila vicinity/ PA/ US
    55K plenum drain service method?
    Remove cover, check for drainage and clean if necessary. I assume this is the cover below the windshield in the engine compartment. Is there anything else I need to know? I searched and couldn't find anything about the B8.
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Not sure, but when I removed that cover to install my strut tower brace, I pulled a whole damn tree out of it! Oh and a pair of pliers someone left behind lol.
    Will
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Aug 11 2015
    It is the cover under the windshield in the engine compartment and was simple to remove. My drain was completely clogged with leaf bits, so this is very good to check! A shop vac with a nozzle tip cleared mine. Then, I ran a stiff insulated wire through the channel, just to make sure I got it all.
