Page 1 of 3 123 LastLast
Results 1 to 40 of 86
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    Zeitronix Flex Fuel Sensor / ECS Boost Tap / P3 Gauge Installed
    Nov 16 2015
    DFW
    Thanks to AndThen!
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    Looks good man!
    Established Member Two Rings Tod's Avatar
    Jan 13 2016
    Nw burbs Chicago
    Looks nice!
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    2012 Prestige, TI package b8 S4
    Past fun,
    2008 SRT8 Jeep pwr 440 Blown by Vortech
    1996 Eclipse GSX bunch of crap
    1996 Slp SS 383 Blown by Vortech
    Mar 21 2015
    Nice job, any issues with the vent while installing the gauge?
    Nov 16 2015
    DFW
    Hardest part was getting trim off and the lil plastic cover for the cable behind the vent. (Lil black thing). We ended up not putting it back as it seems pointless.
    The flex fuel sensor was a lil tedious because of the damn clamps Audi uses on the fuel lines
    Nov 16 2015
    DFW
    Painters tape goes a long way for the Vent!
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Where did you pull power from for the sensor/gauge?
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Nov 16 2015
    DFW
    Quote Originally Posted by BlownOne View Post
    Power for Gauge comes from ODB2.
    Power for sensor since the goal is for it to be on only when car is on... Pulled from ESC fuse.
    Senior Member Two Rings Shantb13's Avatar
    Jun 22 2014
    2002 vw jetta station wagen
    Fullerton , ca
    I have the same set up ;)
    Nov 16 2015
    DFW
    Quote Originally Posted by Shantb13 View Post
    Its amazing!!!
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    Nice job on install.
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    Very cool. Prepping for full e85 or just wanted it for your 93/e85 mixes?
    Nov 16 2015
    DFW
    Nov 16 2015
    DFW
    Quote Originally Posted by mrmomo313 View Post
    Prepping!!!!!
    Will see if I need the HPFP upgrade and that will be next step
    Nov 16 2015
    DFW
    Thinking I should route the harness along the fuel line
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by GRUMPY-S4 View Post
    Damn, the intake looks good. Must be the install.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Nov 16 2015
    DFW
    Quote Originally Posted by jran76 View Post
    Its does!!! Thanks to you!
    Veteran Member Four Rings Whitee's Avatar
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    Excuse me for my ignorance but can you explain the benefit of the fuel sensor? Is this just so you know what percentage ethanol the fuel you're using is? Or does this allot you to run e85 only?
    2010 Prestige Ibis White S4
    Rock Euro | P3 Scanguage | EPL Stage 2
    Mar 21 2015
    Quote Originally Posted by Whitee View Post
    Just for you my friend compliments of google
    http://www.zeitronix.com/Products/ECA/ECA.shtml
    Veteran Member Three Rings Chandler's Avatar
    Jun 07 2014
    Recycle Bin
    South East
    It would just tell you the contents. You would have to select/ modify your tune based on your findings. IE, you are running a full E85 tune yet you got a HORRIBLE batch and it is only 55%. The recommendation here would be to use a map switcher and run a tune for E60 or if you have a 93/E85 mixed tune. The ECU will adapt somewhat, but it can only compensate so much.
    "People who think they know everything are a great annoyance to those of us who do."
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    I read this but what I gathered was it was just a measurement tool. My question is....does this have anything to do with allowing you to run 100% e85 or does that require a hpfp
    Veteran Member Four Rings UkuRiSh's Avatar
    Jan 09 2010
    New York
    I used on my A4 this brand and cheaper too, can display on smartphone
    http://flexconverter.com/
    2013 AUDI S5 4.0T SWAP 9.7@145mph < Press @svarog_performance < last test updates
    Nov 16 2015
    DFW
    Its just to know what percentage of ethanol I am running. Just cUse it says E85... It rarely is.
    Jan 26 2015
    2017 XC90, a workbench
    CO
    Quote Originally Posted by UkuRiSh View Post
    Oh sweet! I'd like to know more about how itis installed. Kudos for building that badass twincharged setup too.
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Nov 16 2015
    DFW
    The Sensor doesnt bypass the need for the hpfp upgrade
    Nov 16 2015
    DFW
    Does their sensor output 0-5V????
    Jun 07 2014
    Recycle Bin
    South East
    +1
    The B8 will need a HPFP upgrade to support the pressure needed to transport the e85 to the injectors. The injectors can handle the increased demand for fuel, the pump can't. Sillyrabit Motorsports, Solomotorsports have confirmed this per their tuning runs. I assume APR and GIAC who both have tested E85 tunes have had the same findings.
    Nov 16 2015
    DFW
    Quote Originally Posted by Chandler View Post
    +1
    The question Ive seen tossed around is does the 8.5 pump have enough juice
    Senior Member Three Rings Mat@1975's Avatar
    Jun 14 2015
    FRANCE
    Nice Work GRUMPY !
    Did you had to make a special part to attach the fuel sensor ? Looks verry clean !
    I am verry interrested by this sensor. Verry helpfull with E85 mixes and, later, to know if a true E85 tune can be loaded. (based on the minimal acceptable value given by the tuner, ie. E70 i remember, for existing tunes)
    BR
    MAt
    S4 B8.5 AVANT | S-Tronic | Full ADS | Sport Diff | Glacier White
    MRC Stage 2 Tune | MRC TCU Tune | AMS/Alpha Cooler| AWE + AFE filter intake with airbox hole
    KW HAS Springs | H&R Sway bar F&R | Custom 14 mm Front and (13 R / 16 L) mm Rear Spacers | CR-15 Strut Brace
    OEM Rotors | Michelin PSS 255/35/19
    Q5 calipers | Goodridge SS Lines | 2-pieces Girodisc Rotors Front & Rear
    Jan 09 2010
    New York
    Yes! optional 0-5V you can use and connect to any gauges or some cars to the ECU.
    Nov 16 2015
    DFW
    So the tube that says "bluetooth" is the analyzer that outputs the 0-5 volt signal? 0 being 0% and 5 being 100% Ethanol?
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    It looks to me like the Continental sensor is the part that outputs the signal to the bluetooth module. Then the bluetooth module sends the data to your phone.
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Nov 16 2015
    DFW
    Quote Originally Posted by Vogz View Post
    I dont think you can feed the output of the sensor to a P3 gauge. Seems like this setup is married to the Bluetooth module and to displaying on phone???
    Veteran Member Four Rings skiracerblah's Avatar
    Jan 03 2011
    Evo X MR : 290whp, 313 lbs/torque @ 24psi; Evo IX : 383whp, 383 lbs/torque @ 28psi E85
    San Fernando Valley, CA
    If you click on the link on this page for "ECA Youtube Video", that's me and my Evo.... I helped Zeitronix develop this back in 2008ish and was the first one to have it installed
    Sorry for newbie questions, this is my 1st Audi
    Current: Phantom Black '2011 S4 S-Tronic Premium Plus, Sports Rear Diff, JL Audio subwoofer upgrade, Milltek Resonated Exhaust
    Old cars:
    Evo X MR-Touring stock, but tuned by RRE: 290whp, 313 lbs/torque @ 24psi 91 octane
    Evo IX tuned by RRE: 383whp, 383 lbs/torque @ 28psi E85 ethanol fuel
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    the sensor itself has a 0-5v output, you just need to tap into it before it hits the bt module. The conti sensor is a OEM replacement, which the zeitronix one was based on, they just branded it and marked up the price.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Nov 16 2015
    DFW
    Quote Originally Posted by infinkc View Post
    If thats the case... Why would I need the BT module?
    Im still skeptical that just the sensor with no analyzer would net the same results as the Zeitronix
    Feb 14 2004
    S Ã C, CÃ*
    you dont need the bt module, only the sensor and a harness. The p3 guage you use as the analyzer, you set it to read the 0-5v input and calibrate it to 0-100%.
    Nov 16 2015
    DFW
    If this works its much cheaper than Zeitronix
    Nov 16 2015
    DFW
    I still dont believe the sensor outputs 0-5V in a linear fashion that can be interpreted by the p3 or any display
