Results 1 to 12 of 12
    Feb 05 2016
    minooka, IL
    Post Traction light ON/OFF after disconnected battery!
    Just got car back from local mechanic and now traction light goes on and off different times. sometimes it will stay on for few seconds then it will be good for couple minutes, go on again,? battery was disconnected recently and now this started happening, He tried resetting the system and calibrating sensors in steering wheel but said it could be the bad module or steer angle sensor. He is getting code 01826.
    Anyone had problems with those sensors or modules?
    2006 2.0 t quattro, 70 k
    Veteran Member Four Rings pat_do's Avatar
    Feb 19 2012
    Montreal
    It will go away after driving a few miles.
    Feb 05 2016
    minooka, IL
    I already drove over 150 miles since then...same issue.....sometimes it stays on for just few seconds, then other times it will stay lit for 20-30 min of driving....turn off and then again turn on after stopping of making a turn. really no pattern.....still trying to figure out if there is any pattern or triggers....maybe it got screwed when he tried to reprogram it?
    Feb 05 2016
    minooka, IL
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    Possible Symptoms
    Malfunction Indicator Light (MIL) active
    Possible Causes
    Temporary Supply Voltage Interruption
    Steering Angle Sensor (G85) faulty
    Steering Column Control Module (J527) faulty
    Possible Solutions
    Perform Steering Angle Sensor (G85) Adaptation
    See Vehicle specific Diagnostic Procedures for Details
    Check/Replace Steering Angle Sensor (G85)
    Check/Replace Steering Column Control Module (J527)
    Special Notes
    ANYONE out there with same issues/fault codes!!!???
    Nov 21 2014
    Montreal
    I had a similar problem after I disconnected the battery to install subs in the car.
    After a few months fixed it by cleaning the battery terminals with sand paper. Try it, either that or your battery is weak.
    Senior Member Three Rings crazyquik22023's Avatar
    Jan 30 2012
    Brunswick, Ohio
    Quote Originally Posted by adi2nd View Post
    Possible Symptoms
    Possible Causes
    Possible Solutions
    Special Notes
    The adaptation usually will happen by just driving a few miles, but if the adaptation was interrupted after the battery was re-connected, you will need to do it manually. Turn steering wheel 30deg. to the left then back to straight up and down, go to ABS module 03, MB 008, Group 005 should be within +/- 5 deg of 0, Go to login enter 40168, click Do It, Go to basic settings 004, Group 001, Click Go.
    Feb 05 2016
    minooka, IL
    If the adaptation was not done correctly, wouldn't the light stay on all the time? This morning was on after starting the car, then after stopping it went off, stayed off for the whole drive to work (40 miles highway ) then pulling into the lot kicked back on few seconds, then turned off for like 5 sec and stayed on again..?
    Nov 21 2014
    Montreal
    Clean your terminals, you are most likely getting low voltage and that's why it's coming on randomly.
    Feb 05 2016
    minooka, IL
    Replaced battery. car is back in the shop now. they are checking every wire connection or loose wires. .. still the same symptoms...
    Feb 05 2016
    minooka, IL
    so finally problem got narrowed down to bad steer angle sensor.....they want $800 to replace it ($500 sensor+300 labor)
    anyone out there with cheaper alternatives ????
    - - - Updated - - -
    Veteran Member Four Rings IKE20VA4's Avatar
    Apr 08 2005
    Portland, OR
    I have a clock spring that I bought to fix my issue but then my issue went away after I had my brakes done.
    Feb 05 2016
    minooka, IL
    UPDATE. Purchased used clockspring from eBay, changed, took programming at first time...test drove...Problem SOLVED!
    http://m.ebay.com/sch/i.html?_nkw=se....TR0.TRC0&sqp=
