So the PCV that attached to my turbo inlet hose was removed while I hooked up my leak tester. When I took it off a bunch of old black pieces fell out of it so I assume its bad. I can easily blow into both sides. No resistance. I finished the leak test and tightened up the hose leading from my intercooler to the T below the DV where I had a slight hiss. So, no more hissing, get everything back together and I'm STILL not getting over 10psi. Is the bad PCV the issue? I couldnt hear any other leaks with the tester on but my car should be putting out 18psi like it was before. Halp!
