Results 1 to 13 of 13
    Jul 28 2013
    2017 Ford Edge Sport; 2004 Ford Exploder (as my wife calls it) V6, 7 passenger
    Rabat, Morocco
    B8 S4 Front Brakes
    Posted this in the tech thread, but I think it would have better here.
    Haven't replaced brakes in years - but don't remember it being all too complicated.
    Bought new rotors, pads, fluid, steel cables for my 2012 Audi S4.
    Was hoping to buy a hard copy of a Chiltons or Bentleys, but there don't seem to be any for my car, nor did I find a youtube video.
    So - for the folks that have done the replacement, anything I need to be aware of? I know for the rears it requires the VAG (which I purchased) to disable the emergency brake.
    Are the fronts fairly straight forward? Anything to watch out for?
    Anyone have links for a step-by-step instructions?
    Appreciate the help,
    Thanks,
    Paul
    May 07 2013
    Northampton, MA
    I just searched "DIY" and this came up in 2 seconds:
    http://www.audizine.com/forum/showth...?highlight=diy
    Jul 28 2013
    Rabat, Morocco
    thanks, apparently I need to a DIY to my search vocabulary. Appreciate the link.
    Jan 15 2016
    Beaver/PA
    Quote Originally Posted by plev72 View Post
    Thanks,
    Paul
    I used that DIY when doing mine and it worked great. Only thing I will say is I don't believe the compound on the back of the pads is needed (the antisqueal) the retaining spring for the front pads on the outside of the caliper will go flying when you pry it off (both hit the wall in the front of my garage) and is a bit of a whore to put back on. Also my normal caliper retractor wouldn't work for the fronts so I used a handheld quick grip/vise to retract the piston. Also turn the wheel towards the opposite of the side you are working on to get a impact in there if using one. Lastly, I did all 4 corners and the first time I slammed on the brakes to seat them I got ABS to activate and I lost my brakes for a second (seems there was a tiny bit of air in the abs module). After it cycled it was fine for all the seating cycles after it if I went a little too hard on the brakes. Overall very easy job. Getting the stuck wheels off and working on the rears was def harder than the fronts.
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Did they add torque specs to that DIY, dont think i saw them. You will need those if your doing pads and rotors.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Veteran Member Three Rings dizzlesizzle's Avatar
    Nov 19 2011
    Rhode Island
    Fastener Tightening Specifications
    Brake Pedal Bracket to Body Nut - 8 nm
    Brake Pedal Mounting Pin to Bracket Bolt - 8 nm
    Electromechanical Parking Brake Control Module Nut - 3 nm
    Electromechanical Parking Brake Motor to Rear Brake Caliper Bolt - 12 nm
    Front Brake Caliper to Brake Carrier Bolt - 30 nm
    Front Brake Carrier to Wheel Bearing Housing Bolt 1 - 196 nm
    Front Brake Line Connection to Brake Caliper - 20 nm
    Front Brake Pad Bolt - 5 nm
    Front Cover Plate Bolt - 10 nm
    Gas Pedal Module to Brake Pedal Bracket Bolt - 8 nm
    Rear Brake Caliper to Brake Carrier Bolt 1 - 35 nm
    Rear Brake Carrier to Wheel Bearing Housing Bolt - 100 nm + 90 degrees
    Rear Brake Hose in Brake Caliper - 19 nm
    Rear Brake Hose to Brake Pipe Line - 12 nm
    Rear Brake Pad Bolt - 5 nm
    • 1 Always replace after removal.
    --2010 S4, Premium+, Black, 6MT, NAV, B&O, Park Assist, 19" AV-M310 ET35, DTM Style Carbon Fiber Front Lip, VAG, ADS "Lite", ROC-EURO CAI, 5000K HIDs
    Jul 28 2013
    Rabat, Morocco
    I bought steel lines and fresh fluid as well, thus planning to drain the brake fluid completely (or as completely as I can). Should make the calipers pretty easy to handle.
    Is there a wear sensor on our brakes? The local Audi dealership, in whom I have no confidence, told me 3+ months ago that my front pads (at ~43k miles) were down to 4 mm and needed to be replaced... three months later the brakes work fine and I've yet to hear a squeal beyond the usual periodic Audi dust annoyance.
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    there is a wear sensor on the fronts--its on the driver's side.
    Veteran Member Three Rings carlosvjr92's Avatar
    Nov 25 2015
    Miami, FL
    Yep there's a wear sensor, but according to the service advisor that last worked on my car you should disregard it and change your brakes before the sensor goes off. He said if you wait until the sensor goes off you'll need to get rotors and pads. If you get it done before hand you might not need rotors too. Not sure how right he is on that though so don't quote me lol
    2018 RS3 (Cumulus Blue) - APR Stage 2 || APR Intake || APR Downpipe
    Jul 28 2013
    Rabat, Morocco
    thanks, that sounds about right the idea being that the wear sensor will gauge the disk. I bought new front disks for the car as I'd been told folks don't really turn the rotors for our cars. Not sure the truth in that though. Figured it was a good opportunity to put on performance pads and rotors.
    Jan 15 2016
    Beaver/PA
    Quote Originally Posted by cspcrx View Post
    I just torqued em to tight. I'm a big guy so my tight is pretty tight. Normally do all my brake jobs that way and no issues lol. I do tq lug nuts however since my tq wrench actually fits. So hard to get em in a wheel well esp the rears
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Quote Originally Posted by djt81185 View Post
    The toughest bolts to loosen are the caliper carrier bolts, and technically I think they recommend replacing them, but most folks don't do that and haven't had any problems.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Jan 04 2013
    Phoenix, az
    I used to do that until I snapped a bolt and it cost twice as much as a torque wrench to fix it. I have multiple wrenches of different sizes so I do not run into that issue. But I understand your position.
