I just bought a 2000 a6 2.7t with 180k. I got a great deal on it because it is in need of TLC. The R/R caliper was right on the rotor and absolutely destroyed both the caliper and the rotor. I changed out the R/R caliper with a new one and did brakes and rotors all the way around.
Now the problem..... The R/R brake pad, in the new caliper, is rubbing the rotor and heating it up to the point where the rotor is blistering hot along with the wheel. I'm assuming the kid had the same problem based on the condition of the R/R brake assembly. This seem common on audi and VW but have not found a defiant I've answer online to fix it. Please help!
The hand brake inside the vehicle has full travel and zero resistance, it feels like it's not connected and does not stop the vehicle. The cable needs to be adjusted or replaced. The new caliper was bled and the res was topped off.
Sent from my SM-G360T1 using Audizine mobile app
