    Dec 30 2014
    Nogaro 2000 S4 6-Speed, Ebony Pearl 2002 A4 5-Speed
    South Carolina
    Help with ground wire location thanks!
    Hello,
    My car has been apart for a while and I forgot where this ground wire goes. It lives near the passenger side engine mount. One end of the ground wire is bolted to the unibody frame rail the other end is loose, does it bolt to the engine mount itself? I can't remember help me out guys!
    Here's a pic of the wire in question.
    http://s482.photobucket.com/user/KHA...g.html?filters[user]=144480118&filters[recent]=1&sort=1&o=0
    Veteran Member Three Rings Let it snow's Avatar
    Aug 24 2014
    02 1.8TQ Sport 5 speed, 05 1.8TQ 6 speed
    Vermont
    I found this assuming you have 1.8T. Yours is the black one. The clear copper one is an add on obviously.
    It is from this. http://www.audizine.com/forum/showth...Ground-Upgrade
    Dec 30 2014
    South Carolina
    Yes I do have a 1.8, unfortunately I'm at work and I won't be able to see if that is the correct location. I swore I looked around the mount and didn't see anywhere the wire would secure too. Thanks let it snow.
    Veteran Member Four Rings DiertyEuroSpec's Avatar
    Aug 21 2009
    Fairfield County, CT
    Its a bolt with a nut and there will be a hole which secures it. Just find the nut and bolt and you'll know what im talking about
    Sent from my LGL33L using Tapatalk
    2003 A4 1.8T Quattro | 18" BBS CH | KW V3 | FT F21 Mixed Flow | MOTOZA | RA4 Stage 1 w/SMFW | Milltek | Uni HFC/3'' DP Combo | 3'' TIP w/MAF | 550cc | TR1.8 FMIC | USP F/R | H-Sport F/R Sway | APR Snub | RS4 Motor Mounts | Stern Trans Mount | Skid Plate | Solid Tie Rod Ends | Short Shifter | Euro Shift Knob | VMR Boost Gauge | S4 F/R Brakes | Tyrolsport Stiffening Kit | ECS S.S. Lines | Hawk HPS Pads | 034 PCV
    Dec 30 2014
    South Carolina
    Quote Originally Posted by DiertyEuroSpec View Post
    You know I had a leftover nut and bolt and was like where the heck does this go. Thanks for the help guys it's appreciated.
