Results 1 to 15 of 15
    Dec 04 2009
    Oregon
    2000 Audi S4 AWE Stage 3 OEM+ Adult Owned - Black on Black
    SOLD
    I am selling my 2000 Audi S4 that I was hoping to keep for a long long time, but due to needing to pay for my kids school, I have decided that its smarter to use the money for that. This car has 152k miles, and has just had every service done to it at 150K (Timing belt, water pump, thermostat, as well as full Stage 3 upgrade... more on that below). Clean title, and when I checked CarFax, no accidents. No oil or fluid leaks, ALL systems and electronics work perfectly.
    This is a rare car, in that a lot of these B5 S4's are just hammered. This car is easily in the top 10% of B5 S4's in terms of quality, care, and tasteful modifications. If you are interested in a well cared for version of Audi S4, that can be as calm as any grocery-getter (my wife can drive this easily), or can come to life and put a huge grin on your face, then this is the car for you.
    INTERIOR
    The interior is a 9.5 out of 10. No sagging headliner, no rips, no scuffs, good soft touch, virtually perfect steering wheel, instrument cluster has been replaced, so no bad pixels.... its all in excellent condition, and has the Audi Motorsport rubber floor mats as well. All LED lights inside (tastefully done in white)
    EXTERIOR
    The exterior is an 8 out of 10, the only things deterring from better score, are some normal rock chips on the front, and a scuff on the rear bumper that looks to have been from a parking incident some time back (I was going to have it repainted to make perfect). Tinted windows as well. LED license plate lights.
    WHEELS
    18" VMR 701 Gunmetal Wheels with Continental Tires, both have less than 2500 miles on them and are in excellent condition (like new)
    SUSPENSION
    H&R Springs with Bilstein Struts. I have ran coilovers on these cars, and they can go lower for sure, but this is an excellent ride height that gives still a great ride, and doesn't cause extreme tirewear. I would do this setup again instead of coils. Trailing arms and bushings were replaced in the last couple of years.
    ENGINE/TRANSMISSION
    This is a Stage 3 car, with factory BW K04 Turbos, RS4 Inlets, AWE Fueling Kit, 034 RS4 Billet MAF Housing, etc. Here is a quick list of items installed in the last 2 to 3k miles:
    - Borg Warner Factory RS4 Turbos
    - Factory RS4 Turbo Inlets
    - RS4 Clutch Kit
    - Baileys Diverter Valves (Black Billet)
    - New Factory flywheel
    - AWE Stage 3 Fueling kit (440cc Injectors, 034 MAF housing, and ECU)
    - Silicon Throttle Body Boot
    - Silicon Turbo Boost Pipe Connectors (otherwise known as lobster claws)
    - 034 Carbon Fiber Cold Air Kit
    - 034 Street Density Engine Mounts
    - 034 Snub Mount
    - New Driveline/Propeller shaft
    EXHAUST
    Full Techtonics system from Turbos back (TT 2.5" Downpipes, with high-flow Catalytic converters, full 2.5" Cat Back.... over $2000 in the ehaust system alone). This system sounds amazing, that is all I will say. Quiet, yet enough throaty sound to get your heart pumping. All stainless as you would expect.
    This car is an amazing car, and if it needed anything, it got it. Car comes with 2 key FOBs as well.
    2000 S4, Bilstein, H&R Susp, VMR 701 Gunmetal 18 Wheels, Techtonics CatBack Downpipes, JHM Snub Mount, Stage 3 with BW K04's, OE RS4 Inlets, Green Top 440s (AWE S3 tune), 85mm 034 MAF, 034 CAI and Samco Lobster Claws.
    2004 S4, Arctic White, KW V1 Coilovers, VMR 710 19" Wheels, Hotchkis Front and Rear sways, JHM LWFW, RS4 Clutch, JHM Intake Spacers, Snub Mount, 4:1 Torsen Center Diff, Miltek Full System, Unitronic Stage 2+ Tune, Tint.
    Aug 15 2012
    garage items
    Montana
    I have a solution for you. Tell your kid to join the military, do 4 years and use the GI bill after for "free" college. He gets valuable life experience and free college, you get to keep your baby. problem solved.
    Dec 04 2009
    Oregon
    That would fix the problem if it were college that we are paying for. Thanks for the bump
    Veteran Member Four Rings Yuppie's Avatar
    Feb 14 2005
    Houston, TX/ Richmond, VA
    It sounds like you are the original owner. Is that correct assumption ? Did you buy the awe kit bought used or was it brand new? Very clean car.
    2001 S4 Sil Sedan ASP Stage 3-Current
    2001.5 S4 Sil Avant Stage 3 IE Rods, CNC 2.8 heads, BW RS6 Turbos-Current
    2001.5 S4 Casa Sedan Built Motor TiAL 770-Current
    2002 S4 Pearl White Avant Stock--SOLD
    2000 S4 Nogaro Sedan EPL Stage III--SOLD
    2000 S4 Brilliant Black Sedan MTM Stage III--SOLD
    2001.5 Nogaro Sedan JFonz Tune Franken F21s--SOLD
    2001.5 Nogaro Sedan AWE Stage III--SOLD
    2001 Brilliant Black Sedan S4-K04/Rs6 Hybrid custom tuned Vast--SOLD
    Veteran Member Three Rings audi-hammer's Avatar
    Aug 28 2009
    Buffalo,NY
    Very clean GLWS!
    Silvia = 02 s4 stageIII
    Dec 04 2009
    Oregon
    Quote Originally Posted by Yuppie View Post
    No, I am not the original owner, I think I am third. I bought it from the guy that had it for most of its life, and I know the shop that serviced it. Like I said, if it needed anything, it got it. And, if it needed anything, and an upgrade made sense, then that was done.
    I bought the AWE setup, and BorgWarner K04 Turbos, and all parts for the Stage 3 setup, and paid to have it installed. When they dropped the engine/trans to do the Stage 3 setup, I had the shop do the water pump, Timing belt, all rollers, valve cover gaskets, etc.
    I am looking into some creative ways to keep the car, so we will see. As for now, its still for sale, but hoping I can hold on to it.
    Veteran Member Three Rings Jmills's Avatar
    Jun 20 2012
    Clean Car man! Good luck with the sale!
    '00 Hibiscus Red Pearl B5 S4 203k on stock k03s! MTM Stage 2...273 AWHP 344WTQ - SOLD Sadly
    2006 Tarmac Black Evo IX 325whp 310 wtq - Daily while I figure out the next Audi
    The Other FB group, the SFW English speaking one, 10,000+ Members
    Junior Member Two Rings Xpendable's Avatar
    May 25 2015
    West Monroe, Louisiana
    Where is this located?
    Senior Member Two Rings rubbndubbn's Avatar
    Dec 27 2010
    Twin Cities, Mn
    Portland Oregon
    Current
    2008 Touareg V8 - Kid Hauler
    1965 Ford Fastback Mustang - Garage Ornament
    Past
    2004 Audi Allroad | 2001 Audi S4 | 2008 VW Passat 2.0t | 1993 VW Corrado VR6 | 2003 Audi 1.8TQ Manual Avant | 2004 VW .:R32
    Veteran Member Three Rings S4gasm aka LOTR's Avatar
    Sep 30 2006
    01 S4 Santorin 6 Spd
    Missoula, MT
    beauty, I think you're selling it too cheap, but what do i know! GLWS
    01 S4/ Stg 3+/K24/+stuff
    08 A6 Avant/ S-Line/ 3.2/ bone stock
    Build Thread - http://www.audizine.com/forum/showth...ld-91-craptane
    Senior Member Two Rings Lanorg's Avatar
    Apr 22 2013
    Floor jacks, torque wrenches, and winter tires
    clean. GLWS
    Jun 14 2005
    Anaheim, CA
    beautiful car! Classic lines.
    Good luck with sale!
    Brandon @ VMR Wheels
    Dec 04 2009
    Oregon
    Dec 04 2009
    Oregon
    Bump back up top
    Dec 04 2009
    Oregon
    Still for sale
