Results 1 to 17 of 17
    Dec 06 2015
    Miami
    0% wastegate duty, 5-6 psi stage 3
    recently refreshed my old vat stage 3 (ko4,42lb, rs4 maf, etc) with a jfonz tune. Car is only boosting 5-6 psi no cel slight rough idle might just be the stiff engine mounts no noticable misfires. boost tested, changed spark plugs, changed n75 valve with known working unit, im out of ideas no clue what it could be. sent josh some logs today just posting to get some input from you guys
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Graphs might be easier to decipher, or even better, just post the .csv.
    No cel, or no codes? Did you scan it?
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Dec 06 2015
    Miami
    unfortunately thats what the shop emailed me they didnt give me the csv file, had some misfire codes but took care of them they were bad coils. for now no lights still running 5 psi
    Nov 16 2010
    WetSide, WA
    Misfire will put it in limp.
    No cel does not mean no codes. You need to scan it with vagcom.
    Plenty of stupid shit on these cars will put you in limp with a code and not throw the light.
    Dec 06 2015
    Miami
    sorry guys yea thats what i meant with no cel before logging checked for codes and nothing came up, i thought limp mode was 10% duty cycle not 0%?
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    There still may be shadow or soft codes
    stored some that are bad enough to put the
    car in limp mode. It's happened to me recently
    on a BMW. Only hard codes set the CEL. Also
    after fixing the misfires did you clear everything
    through the scanner?
    Nov 14 2013
    Never mind just read your last comment.
    What part of Miami are you in?
    Dec 06 2015
    Miami
    Quote Originally Posted by landfill View Post
    kendall area, im hoping its just something in the tune that needs to be tweaked
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    Just curious, but if the car is running lean it can go into limp. The usual, "Have you measured block 32?" would be the next go-to.
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    100.8 percent engine load, requested boost is 2530, actual is 1410.
    no bueno, but you knew that already
    Veteran Member Four Rings phila_dot's Avatar
    May 26 2010
    2001 S4, 2019 Q5
    Philadelphia
    The only conditions that should cause 0% wgdc are:
    - Target boost pressure < atmospheric pressure
    - critical throttle faults
    - N75 open circuit
    You do show two records at 10% dc, but you really need better logs. Your short term fuel trims are pretty high at the top of the second log.
    Conditions for 10% dc:
    - barometric pressure sensor error
    - MAP sensor error
    - baro / MAP comparison error
    - critical misfires
    - boost control error
    - long term fuel trims (upper or lower range error >= 20%)
    WTB (1) OEM A8 Flat Five 18x8.5 et45
    WTB Black 6spd Shift Surround
    May 05 2015
    Texas
    If this is your first base tune he is checking to see what kind of wastegate psi your set at. I also have done etunes with jfonz and experienced this same thing.
    Nov 19 2014
    Portugal
    If that was the case, he should not see 10% wgdc, should he?
    Dec 06 2015
    Miami
    Quote Originally Posted by USephirothU View Post
    I hope it's that, I've literally checked everything and everything's good. I've heard from a shop down here that he did the same to a customers car.
    May 26 2010
    2001 S4, 2019 Q5
    Philadelphia
    Quote Originally Posted by armageddon- View Post
    This.
    If it was for tuning, wgdc would be locked, so there wouldn't be that flash at 10% in your log.
    May 26 2010
    2001 S4, 2019 Q5
    Philadelphia
    Depending on his method, it actually is possible that he does have you locked at 0% for tuning.
    If he locked it to zero in the PID function, then limp could still trigger to 10%. That would be a weird way to do it though.
    Dec 06 2015
    Miami
    Just a quick update I was the tune I guess he turned off the n75 to make sure the car was running right with 5 psi before giving me the full 22. Car is now boosting 22 still some work to be done (little more lag than usually, play with timing for more power) back to logging can't wait for my e85 tune. Solomotorsports/ jfonz = awesome
