    Feb 12 2008
    Michigan
    for those of us running B6/7 S4 front brakes, I have a questiom
    After it was made known that the Q5 3.0 tdi calipers are direct bolt on to our cars with 345x30 rotors I was under the impression that the Q5 3.0 rotor and the b6/7 S4 rotor are the same. They are the same size, but I wonder are they the same offset?
    ECS sells the 345x30 Q5 rotors for cheaper than they sell the S4 345x30 rotors, I have the ECS slotted gemet coated s4 rotors (I love them too), they cost 279/pair
    that same (?) rotor for the Q5 is 189/pair.
    so can we save money by buying Q5 rotors?
    Q5 rotor
    https://www.ecstuning.com/Audi-Q5-Qu...ors/ES2189933/
    s4 rotor
    https://www.ecstuning.com/Audi-B6_S4...ors/ES2189771/
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    WNY
    Links go to a 404 error for me.
    S4 Rotor Dimensions:
    Q5 Rotor Dimensions:
    But to answer your question, I would say no going by the different heights/offsets. However, 5mm isn't a huge amount so you might be able to.
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
    Feb 12 2008
    Michigan
    fixed
    Q5 3.0 tdi rotor is 345x30
    Jan 09 2009
    FL
    Check out autoanything. I got stoptech slotted rotors for a decent cost when I was shopping around a couple months ago.
    Feb 12 2008
    Michigan
    I found the q5 rotor is compatible with the b8 s4, so no go for us.
