Mr. Wong, Are you trying to scare me now! ...'Oh wait, if you're looking at that one though, then be very careful...'
smh..??
I wouldn't be able to buy it from a forum member, although I know that would be ideal, for the simple reason that I would be planning on financing about half of it..
I wish I had $25,000 cash sitting around though
I'd try to buy that immaculate dolphin gray supercharged one!..Or $35k rather! ;)
What is the Wong approach though Mr. Wong?
I realize that a good look under the car is always the best thing to do, but Audi's are hard to look under without a lift. I take a very good look at everything else however, coupled with a long test drive, and then I let the car run for about a half an hour while i look over the exterior and consider all the factors and details. Do you pay for a pre-purchase inspection EVERY time you buy a vehicle? just curious.
Also, research. Isn't that what i am doing here right now?
I've done half a dozen searches for b7 rs4 oil consumption, and from what i have gleaned there is not much information out there....so I guess that is good. Although at the time, there were, what did u say the numbers were...? what probably less than 10% of the number of S4's..?hence there will be a lot less online horror stories to read. Also, most RS4 owners a.) are likely to take better care of their vehicles, and b.) can afford better service and better repair work, so there are likely to be less "oil burners" on the road.
(I was a Biology major btw...so I am pretty decent at research methods.) Ones that end up at used car lots with multiple prior owners though have to scare you a little bit. Why did it change hands so many times..
Sooo... if the car had lets say 3 previous owners, 100,000 miles, a clean Carfax without much data on it, and looked and drove pretty clean and tight, at a used car dealership out of state....Would you find a local Audi Mechanic and pay him to do a leakdown test?
**Does the car have to be put into service position to turn the crank by hand, and the valve covers pulled in order to make sure the valves are closed on each cylinder during testing, in order to do accurate testing?
I wonder what a competent Audi mechanic would charge to do a thorough leak-down test on each cylinder of this motor, and how long it should take him in total..?
Thanks
