Results 1 to 10 of 10
    Established Member Two Rings LurkAllDay's Avatar
    May 27 2015
    Centreville, VA - MAIC
    Spark plug with oil on threads concern
    Did spark plugs yesterday and saw that the bank 1 spark plugs had a bit of oil on the coil packs and spark plug themselves.
    These pics are of the plugs from today.
    Saw threads on other models, but nothing specific to the 3.0t platform.
    Thoughts? Cause for concern?
    No CEL, no misfires.
    Sent from my SM-N920V using Tapatalk
    12 S4 - GIAC Stage 2 w/ TCU tune - USP intake - AWE Resonated DPs - AWE Touring - 034 Trans Mount - CR-15
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Are you sure that's oil? Tips don't seem fouled.. Then again need a good pic from up top
    Could be just the dielectric grease melted.
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    looks normal to me nothing out of the ordinary. No cause for alarm. If its wet then its a concern.
    May 27 2015
    Threads weren't drenched. Maybe a drop or two of oil
    Veteran Member Three Rings u2nelson's Avatar
    Oct 08 2012
    Home of the CR-15 brace
    Palmdale CA, United States
    Agree, nothing looks out of ordinary to me...I don't really know what the burned on stuff is, but seen it many times. Is this the side of engine with oil filler cap? Could just be some old oil that spelled one fine day years ago.
    2013 S5 6MT / Monsoon Grey / APR Stage 2+ / AWE Touring+Res DP / EC Alu-Kreuz / EC USS system sways and links / Bilstein PSS10 coilovers / SPC ADJ UCAs / Spacers H&R 5R / EC Adj Short Throw Shifter / EC TF intake / Apikol rear diff mount / O34 Trany mount insert / BC Forged RS41 19x9.5ET20/ Mich PS4S 265/35/19 / Gyrodisk 2pc rotors / CR-15 Upper Strut Tower Brace / [email protected]
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Oil is leaking from valve cover gasket/seal around each spark plug hole.
    Established Member Two Rings darkstarghost's Avatar
    Feb 08 2014
    2014 Estoril blue s4
    my car did this until i replaced the valve cover gasket. its a easy task and only 70$ a side.
    Jan 09 2008
    Winnipeg
    Could it be anti-seize that just discoloured from the heat?
    May 27 2015
    Thanks for the input all. I'll pull the plugs in a few thousand. If it's still having this issue I'll look into doing the valve cover.
    Edit: damn autocorrect
    Veteran Member Four Rings amz's Avatar
    Apr 29 2013
    Ottawa
    Quote Originally Posted by LurkAllDay View Post
    Please post a DIY if you decide to do the valve cover. Even if we have a DIY currently, having more DIY's is never a bad thing :)
    2012 S4 ~ Phantom Black - Mustang Brown - B&O - Sport Diff - DSG
    AWE Touring Exhaust | Roc Euro Intake | Eurocode Alu-Kruez | Eurocode USS Swaybars & Solid End Links
    Canada: the land of Quattro
