Results 1 to 9 of 9
    Active Member Two Rings tenretni521's Avatar
    Jun 15 2012
    Akron, Ohio
    Hub bore size A6 C6?
    I've done some digging and am getting mixed results.
    On our C6's, is it 66.6mm hub size or 57.1mm?
    Shopping for wheels and am trying to avoid needing rings as I've had bad luck with them in the past.
    Thanks
    2007 Audi A6 4.2 | Oyster Grey
    Jul 17 2011
    Sin City, USA
    Our hub bore is 57.10mm. What "bad luck" did you have? I am running aluminum Hub Centric rings (purchased from ECS) on my wheels and have no issues.
    '09 C6.5 A6
    Jun 15 2012
    Akron, Ohio
    Bought some cheap plastic ones before that fell apart.
    I'll just order the aluminums from ECS.
    Thanks for the info.
    Jul 17 2011
    Sin City, USA
    Any time!!
    '09 C6.5 A6
    Veteran Member Four Rings c@@kieMonsta's Avatar
    May 17 2009
    Idaho
    Not to thread jack, but I'm going to be taking a look at set of 19's off of a C7. My understanding is that the hub bore on the C7 is bigger (66.6mm) so I would be needing hub centric rings. Anyways, the ones I found on ECS are plastic and after reading the above posts, I'd want to go the safe route and get better quality ones. I couldn't find aluminum ones in the section that I was looking under "hub centric rings". Any assistance would be greatly appreciated, thanks!
    Current:
    2019 Ford Expedition
    2009 3.0T A6 Avant w/Prestige package, Side Assist, and Cold Weather package
    2016 2.7 EcoBoost Ford F-150 XLT SCREW
    2007 3.2 A4 Deep Sea Blue Avant
    2006 A6 Arctic White Avant
    2002 1.8t A4 Sedan
    Jul 17 2011
    Sin City, USA
    I have a spare set rattling around in my truck. They are yours if you want them. No charge just pay shipping.
    '09 C6.5 A6
    May 17 2009
    Idaho
    PM'd!
    Current:
    2002 1.8t A4 Sedan
    Senior Member Three Rings S5boxster's Avatar
    Sep 14 2016
    986 boxster
    East Brunswick NJ
    https://www.ecstuning.com/b-ecs-part...ur/ap666571~k/
    U need these to fit the rims as your hub size is 57.1mm
    Sent from my Pixel 4 XL using Audizine mobile app
    Sep 14 2016
    986 boxster
    East Brunswick NJ
    U need these hub rings to make the rims work
    Quote Originally Posted by c@@kieMonsta View Post
    PM'd!
