Results 1 to 15 of 15
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Alignment question...
    So I went to Les Schwab to get an alignment after installing the H&R Sport springs and have come to an issue. They aligned it and I left with -1.8* -2.1* camber in the fronts which is fine, but the car pulls to the right so bad that it changes lanes when you let go of the steering wheel. Schwab refunded my money and recommended going to a place that does both conventional and sub frame alignments.
    I contacted a shop and he said he can get the car to go straight, but the negative camber will still be present unless I go with adjustable control arms obviously. I just realized that you need two Spc control arm kits to do the whole front which costs $850😳 What did you lowered guys out there do??
    Will
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Dec 14 2011
    Chagrin Falls, Ohio
    That's not enough of a difference in camber to cause much pull. How are your tires? Try changing them side to side and see what happens.
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    One SPC kit covers the front, and it should be $400-450.
    It definitely won't make a difference in the car pulling to one side as that's something else. If you keep toe in check and rotate your tires, wear will only be slightly worse than average, so it's your call on the arms.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by Silveravant View Post
    Tires are brand new with knobbies still showing. Drive straight as an arrow before lowering
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by jran76 View Post
    That's exactly what I thought, but eurocodes site says otherwise.
    I'll post a pic of the alignment specs, but nothing was too out of whack...everything was mostly within oem specs. Ive personally never used adjustable arms on any of my vehicles and they have all been lowered. Thanks for the input jran!
    Will
    Veteran Member Four Rings jokingjimmy's Avatar
    Oct 20 2014
    Mk2 TTS Raodster Scuba Blue
    Pittsburgh, PA
    I lowered a bit on KW V3s with stock control arms. 10k miles an tires and pretty even wear, I think they are aligned at -1° camber. Not sure why your car is behaving that way. Sounds like some kind of damage to control arms, bushings or something.
    Everything graciously mispelled by Apple
    Current: 2013 TTRS Suzuka Grey
    Also: 2011 TTS Roadster Scuba Blue
    Previous:
    2014 S4 6MT Nogaro Blue Pearl
    2016 TTS Sepang Blue
    2013 A5 Midnight Blue
    2013 VW GTI DSG Grey
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by BlownOne View Post
    Will
    Some places sell them as one kit per wheel, but EC either has their prices wrong or they are selling as a set and the description is wrong. Modded Euros has them for $229 each. Either way, the whole set should be under $500 if you go that route.
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Amazon has the arms for $226, and AWE has the full kit listed for under $400.
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by jokingjimmy View Post
    Yea I'm not sure why it's pulling severely to the right either...even with the current amount of negative camber, it's not that far out of oem spec.
    Dec 30 2015
    Sacramento, Ca
    That could be possible that one or the other is listed wrong because I thought one set did the whole upper front. Only reason I'm really considering doing the arms is the fact the bushings were trashed when I pulled them.
    Shit that's cheap on Amazon, but I wonder how old the kid was that assembled them in the sweatshop😂
    Dec 30 2015
    Sacramento, Ca
    Here's the current alignment specs from Les Schwab
    Oct 03 2015
    Suisun City, CA
    Nothing there that should cause a pull. However, I'm wondering why they didn't adjust the rear toe back into spec?
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by JeromeS13 View Post
    That's what I was thinking! They just gave up for some reason and refunded my cash.
    Jun 07 2015
    B8.5 allroad, Jag F-Type R, B8.5 Audi S4, Ford F150, Ducati SF
    Centennial, CO
    If it makes you feel better, I have the same issue. I bought my springs used and were advertised as OE, but the way the car is dropped I'll say they're sport. Anyways, went back to alignment shop and everything was fine, rotated tires, still the same. When my car was at the dealer they put it on the alignment rack and it checked out. we're guessing it's the bushings. After driving it for a while things are better but not perfect. Not going to mess with it for now as I'm planning on going coil overs.
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by Yousef View Post
    Ahhh shit well that sucks, but atleast I'm not he only one lol. Idk because my control arm bushings were already cracking when they were removed to install the springs, but maybe with the drop there's more stress on them and there slop is causing it?? Nothing that scrubs speed better than it driving to the right hahaha. Post up in here if you get your issue sorted before I do.
    Will
