Hi guys, my b6 just jumped timing and the whole intake and upper timing covers are off the car now due to an attempted "quick" repair by a shop, so the car isn't running and sitting in my yard. Now I am in a position and on the fence about whether to pull the motor and fix it, or not if it is just a junk motor anyways, after realizing this will cost me a few grand and some time. The car was consuming quite a bit of oil before this all happened and so I'd really rather not do it if this motor is just bad and its going to keep drinking oil. (I was adding almost 1-2 quarts PER WEEK! which is too much!).
I suppose I need to do some proper diagnosis now to see if this motor is worth saving and putting back on the road.
I guess I need to do a leak-down test, boroscope the cylinders to look for any scoring (although some is normal, correct?), and then check the valve seals and valve stems to make sure they are good and not leaking.?.
I'm a little new to this sort of work. I've done compression testing, but thats as far as I've gone in the past as far as this diagnostics. Could anyone point me in the right direction.
Will all of these tests, if done correctly, tell me yes or no whether the engine is worth salvaging? Is it pretty cut and dry and obvious or not once these tests are done, if I go through the trouble of doing this? i am holding onto hope that the motor is still good. I have been reading more and more about these engines for a few weeks now all over, and heard about dozens and dozens of other's trials and tribulations, and from what I am learning is that it really can be a whole lot of various different things that could be causing oil consumption, and sometimes people may even be condemning their car's engines prematurely as "oil burners/the engine is bad" when it could be replaceable repairable parts and seals and gaskets and all kinds of other little things on the motor. These engines can also leak and seep from over a dozen different locations on the motor I have heard.
Can someone shed some light on any of this, i would really appreciate hearing from the experts? I want to get to the bottom of this.
COURSE OF ACTION:
From what I have heard is i HAVE to put the car into service position to turn the engine over by hand
and then take the valve covers off to make sure all valves are closed on each cylinder in order to do a leak down test on that cylinder (I will try to youtube this), and then is there any way to rent a leak-down tester, or how much is an inexpensive one? or is anyone in the Boston area up for coming to help me? i will pay you a pile of cash.
I want to get to the bottom of this. Mice are probably already starting to build nests in this thing it has been sitting for so long.
Is it Valve seat seals....OR valve stem seals that leak the oil out?
Where are all of the other potential external leaks coming from specifically:
-valley pan gasket
-check valves
-oil filter housing gasket
-valve cover gaskets
-half moon gaskets?
-crank seal
-rear main seal
-oil pan gasket
-?? oil cooler lines?
..there's got to be other locations
Thanks so much for reading and any constructive feedback, in advance. Ben
