Results 1 to 13 of 13
Thread: Need help...
    Junior Member Two Rings
    Dec 15 2013
    abilene texas
    Need help...
    Stage 3 and just recently started getting a p0300 code only, nothing specific. I've got the ICM deletes, brand new 2.0t coil packs, tried a second set of spark plugs gapped at .26,new o2 sensors, new coolant temperature sensor, triple checked all my vacuum lines and seems well from what I can see. Boost gauge isn't showing any leaks and holding boost. I've done a compression test all cylinders are between 165 and 170. New maf sensor, injectors only have 3000 miles with a new fuel pump. The only thing I haven't done is hook up a vag Com since I do not have one
    So any advice would be greatly appreciated.
    Veteran Member Four Rings Yuppie's Avatar
    Feb 14 2005
    Houston, TX/ Richmond, VA
    How far are you from Houston?
    2001 S4 Sil Sedan ASP Stage 3-Current
    2001.5 S4 Sil Avant Stage 3 IE Rods, CNC 2.8 heads, BW RS6 Turbos-Current
    2001.5 S4 Casa Sedan Built Motor TiAL 770-Current
    2002 S4 Pearl White Avant Stock--SOLD
    2000 S4 Nogaro Sedan EPL Stage III--SOLD
    2000 S4 Brilliant Black Sedan MTM Stage III--SOLD
    2001.5 Nogaro Sedan JFonz Tune Franken F21s--SOLD
    2001.5 Nogaro Sedan AWE Stage III--SOLD
    2001 Brilliant Black Sedan S4-K04/Rs6 Hybrid custom tuned Vast--SOLD
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    The one thing you dont have is the one thing you need
    You need to log misfires so you can see what cyl it is, and then do the misfire hokey pokey based on that.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Dec 15 2013
    abilene texas
    I'm in abilene so somewhere around 6 hours or more I believe
    Feb 14 2005
    Quote Originally Posted by ejsa6 View Post
    That's a hell of a drive. If you were closer I could have scanned the car for you. If you happen to make it this way let me know.
    May 16 2008
    WA
    Quote Originally Posted by zillarob View Post
    this right here +1,000,000
    Jul 04 2012
    Woodbridge, VA
    Funny thing: when I converted it removed my ability to see misfires via vagcom. Weird, huh?
    Nov 16 2010
    WetSide, WA
    Quote Originally Posted by vavJETTAw36 View Post
    What exactly did you do?
    Jul 04 2012
    Woodbridge, VA
    Rs6 coils, harnesses, and icm delete. Supposed to be plug and play but having issues with codes.
    Nov 16 2010
    WetSide, WA
    I believe misfire rec is based on the crank sensor so coils should not have affected it.
    I think maf scaling bringing load below the activation threshold is the reason it gets disabled most of the time.
    Some tuners may also do this on purpose to cover for poorly idling injectors.
    Jul 04 2012
    Woodbridge, VA
    Aah I see. I only assumed because I no longer have misfires but have rough idle. Sure it's the damn injectors
    Nov 16 2010
    WetSide, WA
    The measuring blks for misfire will say enabled or disabled in the 4th box.
    What injectors?
    Aug 24 2014
    Newport Beach, CA
    There are some tuners who turn off misfire logging, which if I recall correctly, is easier since the knock sensing can be triggered by very subtle/minor misfires. I have the same issue, jballou and I were trying to log misfires and my jfonz tune wouldn't allow us to log them.
    2024 M3 Comp xDrive
