Results 1 to 15 of 15
    Veteran Member Four Rings dalmation53's Avatar
    Aug 20 2013
    Miami
    Useful Information on spark plugs for Newbies.
    Hello Ziners. I have indeed been ghosting for the past few weeks but I have some info on spark plugs and a little review i will make this short. So I am Jhm stage 1 Tune and I was running NGK copper BKR6E for the last 2 years. replacing them every 15k miles I never liked the bosch ones. for some reason performance was decreased a little. so with the BKR6E's I always noticed a bit of vibration at idle like if I needed motor mounts. start up would sometimes hesitate a little.So I went one step colder to the BK7RE's and holy performance batman. The Idle seems like the car was off... after 3k RPMs I feel the power band and even pushes me a little in my seat. passing power is flawless. So is crazy how one step colder all this changes. they have an Iridium version of those but I like me some fresh spark plugs every 15k because racekor. lol but yeah if you have any questions please feel free to ask.
    Ivan
    Veteran Member Four Rings RAudiB7A4's Avatar
    Nov 08 2010
    2015 Hyundai Santa Fe Sport AWD
    Rochester/MN/Mid West
    I've been running BKR7E's since 2012. I change them every oil change (5k miles). I'll never go back. I started with them gapped at .032 but have had much better results after installing the JHM FMIC for the past 2 years with them gapped @.028.
    DTM_B7_S4
    Previous car: APR_Stage_II+_B7_A4
    Aug 20 2013
    Miami
    5k miles? Damn is really not necessary bro. They still look new after 5k miles. But yeah these spark plugs are amazing. I WOULD recommend it for anyone.
    Sent from my C5306 using Tapatalk
    Ivan
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Well those are what's recommended... So yeah
    Aug 20 2013
    Miami
    Actually if you put the year and model of the car those don't even appear.
    Ivan
    Oct 24 2015
    Perth, WA
    I run BOSCH Spark Plug FR5DTC.
    Step cooler for my tune and tri electrode.
    My respray thread
    Oct 31 2014
    NH
    Quote Originally Posted by dalmation53 View Post
    They do on ECS
    Veteran Member Four Rings jamerican1's Avatar
    Nov 15 2009
    2008 A4 S-Line Titanium TQM, 2000 A4 1.8tqm, 1993 Audi 90S(sold)
    VA
    I'm gonna be ordering a set
    Unf*ckwithable
    Account Terminated Four Rings
    Oct 15 2013
    my mechanic said stock plugs are fine for APR stage 2+. i should try the one step colder plugs. when the engine is cold i can feel the misfires when pushing the gas from a stop to low RPMs.
    Veteran Member Three Rings swaggerwagon's Avatar
    Sep 28 2012
    NC
    BKR7E are the standard heat range for our cars....
    B8.5 3.0T/ B5.5 1.8T
    Sep 28 2012
    NC
    http://www.audizine.com/forum/showth...ent-Guide-v2-0
    This is WAY more informative than this post. Just FYI
    Aug 20 2013
    Miami
    Quote Originally Posted by swaggerwagon View Post
    well yeah This wasn't an information thread it was more like a review from me. but yes the other thread explains everything.
    Ivan
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    lol @ this thread. F5RDTC, PFR7S8EG, and BKR7E, and FR6KPP332S are all great plugs for stock and tuned. And stay away from F5DP0R. There are reports of the spark plug breaking. Spark plug gap range (.028-.032) I'm no expert, but you can go with a higher gap, and some have experimented with this, saying that the vehicle pulls harder throughout the powerband. What I can say, is that as cylinder pressures increase, you will need a tighter gap. The goal however is to have the largest possible gap without blowing out the spark. I believe I'm currently at .036" with BKR7E tuned JHM stg1 and no misfires because the plug is cheap - every 10k they are changed; the car feels great and is super responsive while boosting at 20-21 lbs/inch consistently! I think I ran BKR6E's in my B6 A4.
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Sep 28 2012
    NC
    I get that but your issue was that you were running the wrong heat range Spark Plug to begin with. No pointed that out. But yes BKR7E are bomb
    Aug 20 2013
    Miami
    Lol yeah basically I was for the past 2 years. but now I love this plugs. But I think they will last 15k until they start misfiring.
    Ivan
