Results 1 to 7 of 7
Thread: 2.7t question
    Established Member Two Rings lambaudi's Avatar
    Feb 05 2016
    Indiana
    2.7t question
    Hey I have this a6 2.7t quattro sline... So far I really like the car. 200 a month in maintenance scares me tho. So far I know I need to replace CV boots, address the oil leak (valve cover), and replace the whole spare wheel tire set up.
    I've heard of boost leaks, and oil leaks at the turbos. And how they are a bad sign. How can I determine if I have a boost leak?
    Aug 15 2012
    garage items
    Montana
    You could do all of those things yourself if you wanted, the cv boots are messy but easy.
    You can make a leak tester using an air compressor, pvc cap, air fitting, hose and hose fittings. it clamps on at the beginning of your y pipe and pressurizes the system, listen for leaks. You can also do a smoke test. I'm sure there are already some diy's in here if you look for them.
    Feb 05 2016
    Indiana
    Thank you! That gives me a great starting point. The search function rules all haha
    Sent from my XT1585 using Tapatalk
    Veteran Member Four Rings 02 A6 2.7T's Avatar
    Nov 19 2006
    Too much crap
    WA
    2002 A6 2.7T - 6MT Crystal Blue APR Stage 1
    2002 S6 - 6 MT Black/black
    **SOLD ** 2002 allroad 2.7T 6MT
    Feb 05 2016
    Indiana
    So the gadget described in the PDF is all I'll need to test for all possible boost leaks?
    Nov 19 2006
    Too much crap
    WA
    Quote Originally Posted by lambaudi View Post
    ... and an air compressor
    Feb 05 2016
    Indiana
    Quote Originally Posted by 02 A6 2.7T View Post
    With a regulator!
