Results 1 to 11 of 11
    Veteran Member Four Rings FulhamFTW's Avatar
    Jul 11 2010
    STL, MO
    Warm start issue, car almost dies, no rattle?
    So, occasionally, when my car is warm, it has a weird starting issue. It usually happens if it's only been a few minutes since the car has been shut off. It sputters like it wants to die, then just kicks in and is fine. I have no rattle, plugs and coilpacks are good, no CEL, and no performance loss. It has never happened on a cold start, only on warm starts and it doesn't always happen. I am due for a new battery, but what else could it be? Fuel issue? Filter is relatively new, but pump is original and I'm at 144k miles. I would think there would be codes related to fuel if that was the case though. Anyone have this issue or any idea of what it could be?
    Nov 12 2015
    Oregon
    Can you check your fuel pressure ? It's hard to tell without a proper diagnosis, but reading the fuel trims can shed some light on this. I was watching a video of a diagnosis of a bad/weak fuel pump. VERY interesting stuff. i'll dig up the link if you would like. Might help tremendously!
    My build log
    Jul 11 2010
    STL, MO
    Thanks man, definitely appreciate it. I just don't understand why it only happens on some warm starts and no other times.
    Nov 12 2015
    Oregon
    Yeah I have no clue about the intermittent part. When you have nothing to go off of, it's hard to diagnose an issue. . I watch some videos from time to time from a guy on youtube Called Schrodingers Box. He is a scientist that does mechanics on the side and he explains fuel trims extremely well. Highly recommend watching some of his videos. I like how he goes about his diagnosis. .. it has helped me tremendously.
    My build log
    Jun 18 2010
    2004 Boxster S Special 1953 Edition
    East of Cincinnati
    Hope you get your problem resolved quickly.
    Old Geezer, formerly known as Stud Muffin
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    My buddy told me in cases like that it might be crank sensor going bad. Id look into that. But not sure. Just an idea
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Jul 11 2010
    STL, MO
    The problem is, it's so intermittent and reliant on specific warms start situations that I can't really call it a problem yet. I don't want to start throwing money at it just yet, but I'll definitely consider the crank sensor if it gets worse.
    Active Member Two Rings Sodium's Avatar
    Dec 25 2015
    '06 A4 Avant Quattro 3.2 FSI, '95 Jaguar XJS convertible, '95 Diesel Dodge (Train Driver)
    Austin, TX
    Seems like the thing to do is some data logging using the VCDS software and see what the ECU thinks is going on. There's a whole host of could-bes. timing chain tensioner, fuel pressure sensor, fuel pump, crank position sensor, throttle position sensors, throttle valve, leaky injectors. Stumbling at warm start... hm. Well, you've ruled out plugs and coil packs though those are really are subject to wide temperature differences.
    Time to bite the bullet and invest in software that can perform data logging. Your basic code reader isn't going to give you enough information.
    Nov 12 2015
    Oregon
    iirc, the crank sensor is a potentiometer. They are tested very easily:
    http://www.1aauto.com/content/articl...sensor-testing
    dont just buy one and throw it at the car in hopes that is the problem. One of the only ways to figure out what is wrong is to reproduce the symptoms. THEN you can start a proper diagnosis. Other wise you are just looking for "something" and who knows what that may be. If you have a scan tool just crank and look at the RPM's. If it shows nothing, this is your problem. If it cranks and still wont start but the scan tool shows RPM's, move on to the next component. Back to the basics. Air, Fuel, Spark, Timing, Compression
    My build log
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Quote Originally Posted by FulhamFTW View Post
    I think that this sounds like a warm start vacuum leak. These engines get hot as hell after they have been driven for a little while, then they cool back down while being shut off, and reheated when you are out running errands. During that time the metals heat up/expand, then cool down/shrink, and then heat back up/expand back again.
    To start with do some simple things and check some other things. This is stuff that you can do easily for very little money/time. Check that your MAF boot is on the throttle body really tight because sometimes the clamp isn't that tight and a slightly loose MAF boot at the throttle body can make the engine run like crap. Next check that the plastic 90 degree elbow that goes into the MAF boot is not broken or cracked. Take a look over the hoses from that go from that 90 degree elbow to the Y-shaped suction jet pump and check that the suction jet pump isn't broken. Then check that the 5 mm allen bolts for the intake manifold are tight. Those bolts back out because it is a steel bolt going through a magnesium intake manifold into an aluminum cylinder head. All those different types of metals heat up and cool down at different rates so the bolts tend to back out and thus there was a TSB for that issue. Have you taken out the fuel injectors out recently? I ask because the pintle caps tend to break off and I wonder if the bottom o-rings are not sealing correctly.
    Have you done any work to your car recently?
    Also if you can then scan for fault codes. Even if they are intermittent codes that would be helpful to know.
    Quote Originally Posted by VinnysS4 View Post
    I agree that it would be helpful to see the long term fuel trims. He can check them with a vagcom in measuring value block channel 32 if he hasn't cleared the fault codes in a while.
    Jul 11 2010
    STL, MO
    Quote Originally Posted by JimmyBones View Post
    Lots of good info here, thanks. The last thing I worked on was replacing my sparkplugs and coolant reservoir, but nothing serious. I did mess with the MAF though so I'll check to make sure everything is tight there. I'll see if I can find someone local with vcds to log it for me. I'll let you guys know what I find out.
