Results 1 to 3 of 3
    Jan 26 2016
    Atlanta, GA
    Replacement LED tail light housing
    Hello all,
    Is there a way to replace just the lens, or even the housing, of the outer tail light without having to get a whole new assembly with the circuit board, etc? My L side, outer taillight lens is busted (I have no idea what happened to it), but the lights still work fine, so I'd like to keep them (and as much of my $ as possible) if possible.
    2012 A4 Monsoon Grey P+|6MT| Quattro|S-line w sport suspension| B&O|
    Veteran Member Three Rings kt883's Avatar
    Nov 10 2010
    Stoney Creek
    http://www.audizine.com/forum/showth...D-remplacement
    they are not really meant to be taken apart and are likely spot heat welded but there's a start
    Veteran Member Three Rings S4_SH1640's Avatar
    Mar 15 2012
    Fairfield County, CT
    check ebay, sometimes you can find them for a reasonable price
