Results 1 to 4 of 4
    Veteran Member Three Rings Diamond Dog's Avatar
    Feb 02 2014
    My Chicks Camry
    Orange County, CA
    Map Updates - Please help
    Can't seem to get a straight answer on this. Wondering if anyone local has updated their maps
    I have a 2011 S5.
    Is the Map on a disc or on a hard drive? If its a disc, how to I access it?
    Is the only way to update it to buy it from the dealer.
    The dealer quoted me $750.. That seems way high.
    If it is just a matter of putting in a new disc, is there a source to purchase the disc legitimately?
    Mar 21 2015
    Feb 02 2014
    My Chicks Camry
    Orange County, CA
    Looks like the thread got shut down due to that person taking the maps and then charging people to install it (profiting from it).
    I guess my question is has anyone done a map update themselves? With all the people in S. Cal who can Vag Com, I would think that this can be learned?
    Veteran Member Three Rings sirsycott's Avatar
    Sep 20 2013
    Orange County/CA
    of the two possible ways to do this (that i know), there's actually little to no vagcom required for the update
    the most common way is via DVD that you buy from the dealer which can also be found via part number
    the other method was getting the map updates in the form of an SD card, which autolaunches when you load it in and press media to get to it
    only time you need vagcom is when the memory card doesn't boot up and you have to tweak a setting in the hidden green menu to get it to pick up for the SD card
    write times to hdd for the mmi 3g runs between 15-20 minutes , so i suggest to leave car running if you have a low battery
    fyi , if you check ebay , you can get it for cheap , i got mine for 200ish , then i flipped it back on ebay for 175 shipped
    http://www.ebay.com/itm/Genuine-Audi...8AAOSwX~dWhSoG
    link is for reference btw, just to show you ball park what the dvd costs
    if i recall correctly you can alternatively cut audi out by going direct to navigon or navteq depending on which company is the current supplier , you'll have to do your own footwork from there
    but input and advice can be found on internet if you look hard enough
    2018 TTRS
