Results 1 to 8 of 8
    Senior Member Two Rings sm1287's Avatar
    Feb 15 2015
    2017 Toyota Camry, 2018 Audi A5 Sportback
    Dallas, TX
    APR Stage 1 Supporting Mods
    I am planning ahead for when I do a APR Stage 1 tune. Are there any recommended / required mods to help support the tune? This could mean anything from hardware to liquids (oil, etc).
    For more info I have a 2015 S5, DSG, Sports Diff, (ECS) Kohlefaser Luft-Technik Intake.
    From what I've read there isn't much actually required to go to Stage 1, I'm just being overly cautious.
    Veteran Member Three Rings mjr034's Avatar
    Jul 07 2014
    2015 Mazda 3i GT
    Michigan
    intake is very worth it when doing any tune on these cars, but aside from that, don't need much else.
    2013 S5 3.0 TFSI ~ Prestige | DSG | Brilliant Black | Carbon Atlas
    | 034 | APR | AWE | BBS | BFI | BILSTEIN | ECS | VORSTEINER |
    Senior Member Three Rings Azoriano's Avatar
    Jun 28 2013
    2009 S5 V8 4.2l
    Quote Originally Posted by sm1287 View Post
    You should consider JHM Tune. I believe it's better then APR.
    2009 S5 4.2L V8 6SPD Quattro
    IBIS White with
    Magna Red Leather Interior
    VagCom Coding / Custom Exhaust / Rs5 Grill / KwV3 Coils / AWE Intake / 20" Ag M580
    Veteran Member Three Rings LordMagnet's Avatar
    Jul 20 2015
    Connecticut
    There aren't any requirements for the Stage 1 tune. But the tune works well in tandem with an aftermarket exhaust and intake. It is probably recommended getting the TCU tune for the DSG transmission to get the full benefit from the Stage 1 ECU tune, as the stock transmission settings have the car short shift the gears. But that's an optional recommendation and not a requirement.
    Quote Originally Posted by Azoriano View Post
    I don't believe JHM has a tune for the 3.0T, only the 4.2L.
    2015 Audi S5 Coupe 6MT | Mythos Black Metallic : Black Nappa : Alu-Optic : B&O : Sport Diff. : 19" RS Rims : Carbon Fiber Inlay | APR Stage 2 : Roc-Euro Intake : AWE Touring Exhaust 102mm : EuroCode Short Shifter : USP Clutch Line : CR-15 Strut Tower Brace : 034 Mounts : H&R OE Sport Springs : 15mm/20mm Spacers : Tint 35% Sides / 20% Rear : Interior LED Kit : E-Codes : Vinyled Grille | 413 AWHP / 375 AWTQ
    Feb 15 2015
    Dallas, TX
    Quote Originally Posted by LordMagnet View Post
    So would you recommend getting the exhaust first or after the tune. I read that the car will throw an error if I change the exhaust before tuning.
    Also what TCU tune should I go with? Haven't done any research into this area. And are there any recommended supporting mods for that as well?
    Thanks for your help.
    Veteran Member Three Rings jamin_00's Avatar
    Sep 14 2014
    Essex, UK
    Only air filter or intake with a stage 1 to help it breathe. Nothing else until you go further as the rest is just optional. Its only when you go to a stage 2 that you will need supporting mods to get the benefits from it.
    Stage 1 will give you (with a good tune) 90-100bhp increase on the dyno with just a filter :)
    Audi S5 V6T 3.0 - Black Edition - Stage 2 MRC Tuning - 480bhp 580nm
    Jul 20 2015
    Connecticut
    Realistically, exhausts cost a ton of money, and whether you have a tune or not, really won't net you a whole lot of power. You do exhaust on this platform for the sound. That said, the ECU (with or without tune) should compensate for the increased flow from intake and/or exhaust.
    I haven't read anything about an error being thrown, but I had my exhaust installed after my tune.
    I don't think I'm the right person to advise on the TCU tune, as I have a manual. But there is always a ton of talk on here and especially the B8 S4 forum about TCU tunes, as 90% of owners have the DSG. Don't be afraid to spend some time in the S4 forum, as it's damn near the same car, and is definitely more populated/active than the S5 forum.
    Jan 18 2015
    No code with cat-back exhausts. If you delete your cats then that would trip a code.
