Results 1 to 9 of 9
    Sep 27 2008
    Phoenix
    New (larger) jack, need new jack points
    I'm used to lifting my car on the pinch welds by the front and rear tires but recently picked up a larger floor jack and can't fit the jack and the jack stands on the pinch welds. What are some good alternative places to lift the car with the jack?
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    Buy another jack, hockey pucks. If the lifting jack doesn't fit under the pinch welds, first raise it up a little with the oem screw type jack. Use two jacks to lift up the front of the car using the hockey pucks on the pinch welds (you can cut a groove so it fits the pinch welds). I lift until I can fit some jack stands under the subframe mounts.
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Sep 27 2008
    Phoenix
    The jack fits but not the jack and the jackstand together. I searched for threads on this but couldn't find much other than using the pinch welds.
    Veteran Member Four Rings onedumslack's Avatar
    Mar 05 2014
    phoenix/az/usa
    I use the sub frame to lift it and then jack stands at the pinch welds. This only works if you use a low profile jack from the front.
    Dec 07 2009
    East Coast
    Just buy a damn RS4 jack pad kit and you'll never have to worry about damaged pinch welds, ever...
    Forget the B8, keep the V8!
    May 09 2012
    I know what you're talking about. I just use a hockey puck on my floor jack and jack the car up from behind the pinch welds. Once it's high enough I put my jack stand on the pinch welds. Probably not the best method but I haven't had any problems yet
    2007 A4 2.0T Quattro Tip
    - Autospeed Tune - ST Coilovers - VMR V710
    Mar 10 2004
    08 A4Avant 2.0T
    There is a dude on ebay selling VW Audi urethane "pucks" so you dont crush the pinch welds. I bought one for the B7 and another for the TTS (uses the R8 style roller seat) I'm not going to post the link because lazy and also not affiliated, but It worked just fine. Slightly taller than needs to be but was good for under 20 bucks and can prob be used on many cars with similar jack points. I dont like using any other spot to lift due to the side skirts. I tend to leave the car on the jack and place the stands under subframe points sometimes the other way around.
    '17 A4 Allroad
    '08 A4 Avant 2.0T Titanium Edition
    '11 TTS Coupe (sold)
    '01 A4 Avant 1.8T S line (sold)
    '90 CQ 20v (sold)
    '95 VR6 "Getta" (sold)
    '85 4000s quattro (sold)
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    I put the floor Jack on the little boob under the car. I'm not sure if there are official jackpoints other than the ones shown in the manual but anything subframe related should be fine.
    I still use the jack stands on the pinch points without damaging anything.
    Apr 30 2014
    B8.5 S4, A3 e-tron
    CA, Bay Area
    I use the rear diff to lift up the back and subframe in the front with a low profile aluminum jack
