    Veteran Member Four Rings audi_nightrider's Avatar
    Oct 08 2009
    12 more rings
    Northridge, CA
    2011 A5 2.0T Completely Dead
    So my car just completely died on me. Won't take charge and won't even start even with a jump starter.
    Car only has 76k miles
    No symptoms or anything at all. Even drove the car about 30 mins away from home. And then when I get back to it, pushed the key in, heard clicking sounds, then completely died. Called AAA and got it towed, they also scanned it and they said it's a bad alternator and bad battery.
    Is that completely normal? It just suddenly happen without any symptoms or whatsoever?
    Haven't scanned it with my vag-com yet but what am I looking at here?
    TIA!
    Anddddd...this happened when I'm still on the process of replacing my b6 a4's headgasket
    Silver 02 Audi A4 1.8T Q MT
    '11 2.0T Audi A5 Premium Plus quattro...Auto GONE
    C7 S7 ESTORIL BLUE 4.0 TT Prestige GONE =(
    Veteran Member Four Rings B-Time's Avatar
    May 03 2009
    East
    It's is not uncommon for a battery to die quickly at that age. I would start with a new battery, you are due for one anyway.
    Oct 08 2009
    12 more rings
    Northridge, CA
    ok so I connected my car to another car to jump it.
    Using the MMI display, it does say that battery is at max 100%....
    light, radio, even a/c works except when you try to start it....3 clicking noise but won't start.
    Car dies again right after I remove the jumper cables.
    so battery for sure?
    May 03 2009
    East
    Did you replace it or have it tested?
    Oct 23 2014
    Mississippi
    I agree with b-time. Just because it says it's ok on the meter doesn't mean it's a good battery. I went through a whole order deal with battery issues thinking it was the alternator for over a week. Ended up the alternator harness wire developing a huge short. Hopefully that's not your problem. Battery is easy to replace and minimal coding was needed when I did it myself.
    2010 Premium Phantom Black A4 with Sport Package Suspension and Wheels
