Results 1 to 19 of 19
    May 01 2013
    V8 belt driven motor swap
    Can a belt driven V8 motor from C5 A6/S6 or D2 S8 S be swapped in a B6 chasis to avoid the timing chain issues that happen with the B6 S4?
    Thanks
    Veteran Member Four Rings dsgray16's Avatar
    Jun 11 2013
    Anything is possible, but I think your money would be much better spent by just doing a quality timing service with the mid to high level JHM Kit. Why swap an engine in with older tech that has its own issues outside of the belt vs chain timing difference. Or swap an RS4 motor in ;)
    Events: Time to register for Avantoberfest 2018!: www.avantoberfest.com
    Instagram: Audisport_Wagon
    Cars: Full B7 RS4 Avant swap http://www.audizine.com/forum/showth...S4-Avant-Build
    B7 RS4 sedan in Phantom Black - just a clean OEM+ daily driver
    Sep 16 2010
    Central Wash
    Quote Originally Posted by dsgray16 View Post
    I'd actually like to know this too. Can't be too tough. The Belt V8 is only about 3" longer than the chain version. As as far as issues..it has a leaky oil cooler pipe that's $72 and an afternoon to fix. Can't think of a single other issue..outside of normal maintenance.
    Otherwise...it's about the most reliable engine I've ever known. And you can buy 3 of them for the price of doing the chain service.
    Jun 11 2013
    I'm in the process of doing an RS4 swap, so stay tuned for updates and tips on what I went through. And I'm not doing the labor, but I am involved in sourcing parts and providing tips that I have been picking up from others that have done it. Not for the faint of heart, or wallet, but should end up being an amazing ride.
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    Quote Originally Posted by rollerton View Post
    Everything you said here is spot on. Besides that pipe, the belt driven 4.2 is nearly bulletproof. If it fits nicely, I would almost guarantee that the entire swap would be cheaper than parts alone to service the timing components on the chain driven motor.
    Paging Nollywood.
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
    May 01 2013
    So what would be needed? I know of two shops that did the chains twice and still failed. One shop put a 2.7TT with Franken Turbo's the other shop rebuilt with new chains and still blew up. Its just that like rollerton said they are bulletproof aside from regular maintenance and oil cooler pipe.
    Nov 09 2015
    Devon
    From what I've read about the B6/B7 chassis car the reason they went to the chain driven engine was because the belt driven engine could not be made to fit. 3 inches may not sound a lot but given that the chain driven engine is bloody tight fit as it is I cant see the belt driven one fitting. Bloody shame because this is one of my biggest fears with my car. At moment its sweet as a nut and gets 5k oil changes as a preventative measure. Would certainly be doing the conversion myself if the chains give issue and there was evidence of the belt driven engine being able to made fit.
    Senior Member Three Rings B6ayfour's Avatar
    Jun 21 2015
    2014 S4 6MT, 1989 535i5
    LI, NY
    Sep 16 2010
    Central Wash
    Well, seems like Nollywood does a 4.2 swap to B5 every few weeks! If the 4.2 goes into the B5 reasonably then it's just up to someone motivated to work out the details- because space isn't the biggest issue. The belt driven V8 is really a very compact engine, people have been putting them in Boxters and other little cars these days.
    So, all I need is a car nice enough to be worth it that I don't need to drive. And a Spare V8. And some tools. And more garage space. And a bionic spine. And moar smarter.
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    Quote Originally Posted by S4quattro2015 View Post
    3 inches may not sound a lot but...
    Thats what She said....
    sorry, i had to
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Nov 03 2011
    All Over!
    The 077-series Belt-driven V8 engines WILL fit the B6/7.
    Sure, Audi designed the 079-series chain-driven V8 engines specifically for the B6 S4, because it's approx. 2.5" shorter than 077 series versions. Not because the earlier V8's won't fit, more due to practical reasons - service space.
    I have measured the engine bays of the B5 and B6, from the most protruding section of the firewall, to the lock carrier. Both are close in terms of depth, with the B6 actually having 2" more. The 077-series V8 fits the B5, so the B6 will be okay too.
    I am still on the look out for a B6 3.0 Quattro 6MT as a base car for another V8 swap. My spare V8 was destined for my B5 Quattro 2.5 TDI V6 24V, but this is being replaced by a B6. I will update as things get moving. First, I need a base car!
    1986 Type 85 Audi 90 quattro
    Nov 08 2010
    Upstate New York
    Great info as always.
    I'm a rookie when it comes to v8 swaps. Can the 077-series be bolted up to the 0A3 trans, or is another transmission such as the 01E required?
    - B8 S4, Stage 2+
    - B6 S4, not stock
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Avant Abt AS400 clone, 14 SQ5
    Sunny UK
    What power mods are available for the belt-driven V8s? I've been tempted to try an RS6 V8tt swap, but that would cause a black hole in my wallet.
    -Tim
    Nov 03 2011
    All Over!
    Quote Originally Posted by melomandn View Post
    I'm not 100% sure if the 077 bolts up to the 0A3 using ALL bolt holes, but I'll check.
    Nov 03 2011
    All Over!
    Quote Originally Posted by sandspeed View Post
    Supercharger, or turbo option, using C5 RS6 internals. Which is the route I'm looking into.
    Mar 13 2007
    Sunny UK
    Hmmm....
    -Tim
    Nov 03 2011
    All Over!
    Hmmm....
    ...And it came to pass. I'm doing the swap, with a slight change of direction. A complete built C5 RS6 (BCY) engine, with OEM Bosch Motronic ME 7.1.1.
    Mar 21 2011
    '06 B7/B6 RS4 JHM Stage 1+ S/C, '04 Ford Expedition, '08 Lambroghini Gallardo SL TT
    Dubai
    How's it coming along?
    Nov 03 2011
    All Over!
    Quote Originally Posted by iconic78 View Post
    I've got all the rebuild parts from Audi.
    I'm just looking for a workshop to rent, to start the work.
