Results 1 to 15 of 15
    May 30 2015
    2012 Ford Fusion (wife's car)
    Wellman,Tx
    boost pressure (ive searched)
    Hey guys,
    Before you get on to me about the search button, Ive used it and I am more confused now:
    So my question is :
    What is the stock boost pressure range?
    I used my Foxpro pro scanner for the real time data collection:
    at Idle the boot was 890mbar or 12.9 psi
    at 3500rpm it jumped to 13.8- 14.2 psi
    Is that about right for a pretty much stock motor?
    I am about to change the exhaust to a more free flowing type. I am just afraid of loosing turbo performance and having alot of lag
    Senior Member Two Rings Gotpsi2008's Avatar
    Mar 24 2015
    YFZ 450, Beer Fridge
    Sebago, Maine
    Boost at idle? You should be recording vacuum at idle and under a load is when you will start making boost, as far as the exhaust, you will have a quicker spool due to a better flow of exhaust gasses helping the turbine spin up quicker, and as far as the boost increase that's something controlled by the wastegate so even with an exhaust change you shouldn't see an increase in boost, just more or less a little better throttle response and a different tone. I have no idea what the stock boost is, I'm sure someone will chime in, but at stage 1 I'm surging 18.8 and holding 17
    2008 A4 S-Line Grille 2.0T 6MT Quattro | JHM Stage 2 93 | Autotech HPFP Internals | JHM 3" TP | OBX 2.5" DP | JHM LWFW | RS4 Clutch Pressure Plate Combo | 034 Motor Mounts | 034 Snub | 034 Density Trans Mount | Red Top Coils | AFE Pro Dry S | CTS Silicon Turbo Hoses | ECS Intake Boot | P3Cars Boost Gauge | BSH PCV Revamp | EBC Reds | Ziza
    Veteran Member Four Rings Der Konig's Avatar
    Jul 09 2009
    '06 a4 2.0T 6MTQ, S3 '01.5 s4 avant 6speed, '12 KO4 Audi Q5
    Cleveland OH Area
    Quote Originally Posted by fhh02a View Post
    Hey guys,
    So my question is :
    Regardless, you wont have a lot of lag with the ko3s. What gotpsi is getting at, is that there should actually be vacuum at idle. A spike of that is pretty high but not that uncommon. I assume a spike to that and then holds more like 10-12 psi?
    gotpsi ninja edited, no fair.
    '04 Corvette Z06 track car
    '15 F350 Platinum 6.7
    '06 APR S2+ A4 2.0T 6 Speed DD - current
    '12 Q5 2.0T P+ Built engine/CTS K04/IE tune - current
    '05 Ford F250 XLT 4x4 BP'd 6.0 - current
    '01.5 APR S3 S4 Avant 6 Speed - sold '04 Goodwood S4 6 Speed - sold '91 Jetta GL 1.8 8v manual swap - sold '99 SVT Cobra 08whp/308wtq - sold '01 Mustang GT - sold '88 Mustang LX 5.0 - sold '95 Jeep Cherokee Country - sold
    Nov 15 2011
    Montreal | I sell in USD
    *****I sell in USD*****
    Veteran Member Three Rings supple's Avatar
    Jan 27 2016
    I don't have a garage
    Woburn, MA
    I believe my stock KO3 was pulling around 12 psi and Unitronic stage 1 bumped it to 17 psi. Gotpsi2008 is correct that a free flowing exhaust is mostly sound but wouldn't play much into boost holding. You'll have to make sure you're not leaking and your Diverter Valve isn't torn (if it's the old revision).
    At idle, you shouldn't have boost since you aren't getting your turbo going, so 0 or vacuum.
    Found this on another forum and gives a good explanation of couple things:
    "The Diverter valves serve to divert boost pressure air back to the compressor inlets when the throttle is cut under boost. This avoids compressor stall and hesitation in recovery. They are inactive under acceleration or steady state driving. They don't regulate boost, and have no connection with the waste gates.
    The wastegates divert excess exhaust gases around the turbines to limit boost. They are regulated by the ECU via a control solenoid valve (N75) to conform (approximately) actual to requested boost."
    2013 S4 Monsoon Grey | APR Stage 2 Single Pulley | Roc Euro Intake | 034 RSB + Drivetrain Inserts + Control Arms | CR-15 | KW V1
    RIP 2007 Brilliant Black A4 Quattro | Unitronic Stage 1+ | Bilstein Sport + H&R Sport | Apikol Snub | GFB DV+ | 034 Turbo Inlet, Street Density Motor Mounts, RSB & End Links, Control Arms | Pipercross Filter
    Mar 24 2015
    Sebago, Maine
    Quote Originally Posted by Der Konig View Post
    Like ah boss hah
    May 30 2015
    Wellman,Tx
    Quote Originally Posted by Axis View Post
    I used tht
    And I was more confused after reading it
    May 30 2015
    Wellman,Tx
    Sorry for the newb questions
    I'm new to boosted cars.
    The reason I posted tht number is it was
    Boost, actual
    I thought it was weird tht it was making boost when there was no engine load but I thought it was normal
    Mar 24 2015
    Sebago, Maine
    You should be boosting 10-12 stock. I'm not familiar with the tool your using but I personally IMO wouldn't trust anything but a actual boost gauge, Even though I'm sure there is software and tools that are accurate
    May 30 2015
    Wellman,Tx
    like i said, the number that was recorded at the moment of idle was 890mbar. Which I guess would be negative? Which after extensive reading is normal.
    The tool I was using is a very nice and handy tool.
    like i said, im trying to learn as much as i can about boosted cars
    Jan 05 2015
    London
    You've prob figured this by now but essentially at idle is reading atmospheric pressure. Calculate boost pressure by deducting atmospheric from the reading.
    May 30 2015
    Wellman,Tx
    What I'm looking at
    Mar 24 2015
    Sebago, Maine
    To read atmospheric pressure would be to shut the engine off and then take a reading, that's atmosphere pressure, when the engine is running it pulls in air and makes a vacuum until you increase rpms and combustion to create high exhaust flow which turns the turbine which is on the same shaft as the compressor at a different ratio so it creates boost, aka positive pressure
    Jun 27 2011
    Quote Originally Posted by MrBigglesworth View Post
    This. Any reading at idle is showing atmospheric pressure. The stock setup will not measure vacuum at idle, you need an actual boost gauge for that.
    Deduct the atmospheric pressure from all your numbers and then you get actual boost in mbar. That's an easy Google conversion to psi. Stock the engine should be creating 12psi (depending on the gear) and holding around 10 until almost 5k rpms. If it's significantly less than that you've got problems.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Mar 24 2015
    Sebago, Maine
    +1
