Results 1 to 3 of 3
    Sep 21 2015
    2005 Ford F150 / 2001 Honda CBR929RR Erion Edition
    Kentucky
    AEB manual crank
    Looking for a crank off a MANUAL AEB. Shipped to 40299. PP ready
    Jan 18 2016
    '14 A6 TDI, 01 TT 225Q Roadster Nimbus/Amber Baseball
    NH
    Out of curiosity, what is the difference between a manual AEB crank and an auto AEB crank, besides the removable snout/adapted for the flex plate torque converter? I have an AEB motor I'd do cheap, or separate for the block or just crank, but it was a tiptronic. Here's a picture of the adapter, which can be removed from the crank and a pilot bearing pressed into it's place. http://i.imgur.com/5AbTNtM.jpg
    I did something similar when I converted a '96 A6 to a stick using the flywheel/clutch/transmission from a '92 S4. I had to pull the adapter out of the crank first. 5 minutes using the pilot bearing tool. https://vw.snapon.com/SpecialToolsDe...temid=28550007
    Jul 12 2011
    PSL, FL BK,NY
    Quote Originally Posted by th3cavalry View Post
    I have one how much are you looking to spend???
