Results 1 to 23 of 23
    Active Member One Ring LeventY's Avatar
    Feb 04 2016
    Istanbul/Turkey
    B5 S4 GTX2867 Project
    Hi everyone, would like to share my build that we currently finished...
    Engine/Drivetrain:
    Mahle Pistons
    Pauter Rods
    ARP Stud Kit
    Ferrea Valvetrain
    2.8 Cylinder Heads
    RS4 Intake Manifold
    Wagner Intercoolers
    GTX2867R Turbochargers
    Wagner Exhaust Manifolds
    H&R Coilover and Sway Bar Kit
    996 Turbo Brakes with Tarox F2000 Discs
    SSR V02 Wheels with Michelin Pilot Supersport Tires
    Feb 04 2016
    Istanbul/Turkey
    2.0 bar 90 - 270 kmh Acceleration:
    https://www.youtube.com/watch?v=f8ir2Lx_8r0
    100 - 200 kmh : 5.54 sec
    Veteran Member Four Rings jaychen's Avatar
    Feb 19 2011
    Earth
    Strong as fuck.
    Sent from my SM-G900I using Tapatalk
    2000 Achat S4
    Veteran Member Three Rings B501S4's Avatar
    Sep 09 2007
    01.5 B5S4 Stg III RS6's Built Longblock, Cherokee Classic 4x4
    Raleigh, NC
    Wow. Incredible!
    Veteran Member Four Rings QuinnsterKID's Avatar
    Mar 02 2010
    1989 Ford Mustang LX 5.0
    Las Vegas
    Cleeeeean. Nice build. Have you had a chance to dyno this beast yet?
    2012 Moonlight Blue S4 // Black Optics // Intake and Exhaust // Lowered
    2001.5 Nogaro S4 // 6MT // Stage 3 // K04 // E85 // Daz tuned
    2014 Daytona Gray Pearl Q5 TDI // Black Optics // Sport
    2013 Black A4 Sport SOLD
    2008 Ibis White A6 3.2 Quattro SOLD
    2004 Silver USP A4 Avant 6mt SOLD
    2000 Laser Red A4 1.8 Quattro SOLD
    2001 Santorin S4 SOLD
    Jun 14 2007
    2000 S4
    Connecticut
    Awesome build.. Those turbos are crazy I have been in a larger frame GT car and when they're tuned right it's a wonderful feeling under full throttle.
    Aug 24 2014
    Newport Beach, CA
    Great build, nice choice on the coilovers I have the same ones. That's also about the only thing my car has in common with yours haha. Is it just me or does the acceleration of these cars get faster and faster in 4th and 5th gear?
    2024 M3 Comp xDrive
    Feb 05 2014
    BROOKLYN
    Looking good!
    Aug 09 2012
    2013 S4 phantom pearl
    IL
    this is a quality build! monster result
    Veteran Member Four Rings erykv1's Avatar
    Jul 01 2014
    'murca
    wow amazing. thanks for sharing!
    what kind of exhaust manifolds are those
    -edit- totally missed that you mentioned that in your first post! sorry.
    Feb 04 2016
    Istanbul/Turkey
    Quote Originally Posted by QuinnsterKID View Post
    680 HP & 720 NM on 95 octane Euro pump fuel and methanol injection at 2.0 bar
    Quote Originally Posted by getslideways View Post
    any videos?
    1.2 bar 500 hp: https://www.youtube.com/watch?v=NR7Q7U7xdR0
    1.7 bar 650 hp: https://www.youtube.com/watch?v=0ENJm0CR5IE
    2.0 bar 700 hp 100 octane: https://www.youtube.com/watch?v=f8ir2Lx_8r0
    Exhaust Sound at 1.0 bar :https://www.youtube.com/watch?v=AKB58M9MeRs
    Quote Originally Posted by christianb5s4 View Post
    Haha thank you, have the exact same feeling, really fast at the 4th gear and even faster at the 5th
    Quote Originally Posted by erykv1 View Post
    wow amazing.
    Next step will be 2.5 bar with new upgraded cams and ferrea +1 mm valves.
    Jun 14 2007
    2000 S4
    Connecticut
    Wow that car hauls! You need some serious real estate on the highway to stretch it's legs
    Veteran Member Three Rings Tec_Nine's Avatar
    Sep 17 2012
    Riverside, IL
    Awesome build, looks very strong and well done. Props
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    Nice!
    Dec 14 2008
    Finland
    Just to point out 680 is chp and 559 is whp? It's usually the other way around here when it comes to dyno numbers vs performance :)
    Maybe a little skimpy dyno but Acceleration is mental!
    What's the turbo specs, turbine side?
    What mahle pistons?
    World's Fastest B5 Avant biturbo Full Weight
    With Race Seats @3800lbs
    TTE950+ 100-200kmh 3,81s
    Feb 04 2016
    Istanbul/Turkey
    Thank you; 19 wheels with slicks will hopefully enough for traction
    Quote Originally Posted by Mikse View Post
    What mahle pistons?
    It is a MAHA MSR500 Dyno which measures correctly imo. Here in Turkey crank hp is more important than whp, in US the opposite :)
    Here are the dbn files of 5.5 sec 100 - 200 run
    100 - 200 kmh:
    When we will finish the setup with the camshafts and valves there will be less lag hopefully . Just with a better shifting and less lag the car can reach 5.0 secs between 100 - 200 kmh.
    Specs of the GTX2867:
    COMPRESSOR WHEEL INDUCER: 49.70mm
    EXHAUST WHEEL EXDUCER :53.90mm
    Nov 19 2014
    Portugal
    Brake disc size?
    Dec 14 2008
    Finland
    Quote Originally Posted by LeventY View Post
    My point exactly, you'll find many "600whp" cars here but with much slower times. But even European standards I'd say you have extremely fast car for the power. Unless you have weight reduction.
    A/R for turbine housing? Peak tq is quite high rpm.
    Feb 04 2016
    Istanbul/Turkey
    Quote Originally Posted by armageddon- View Post
    Brake disc size?
    340 mm
    Agree with you, 0.82 A/R , on the last chart that I've posted, between 3.7 and 4.2 sec the car cant accelerate smoothly, after the cams we will rev 8k rpms and solve this problem. The only weight reduction was back seats, but the setup also weights much more than the oem (inkl. me 1700 kg with oem front seats and half tank)
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Las Vegas
    0.82 is really big, considering the GT2871 eliminators for this setup i've seen have an AR of 0.71
    Dec 14 2008
    Finland
    Exactly what turbine housing are those because they look like eliminator housings (machining looks identical with DP flange etc.)? Home-brewed?
    Jan 11 2007
    Salt Lake City, Utah
    Also curious about this.
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
