Results 1 to 40 of 41
    Established Member Two Rings peekaBu's Avatar
    Sep 18 2013
    Mercedes C300
    New York City
    Intake & Audi Warranty?
    So I have a CTS turbo installed on my B8. I'm heading to my dealer for a service and wondering if I should take it off. Has anyone ever received a TD1 with an intake?
    I feel like this is something they could possibly do, under what reasoning I do not know.
    Jun 11 2014
    Ny
    Depends on the dealer, I go to palisades Audi and they are cool with my intake and exhaust.
    May 14 2015
    New York
    Quote Originally Posted by Gkit19986 View Post
    Which intake do you have? That's where I go to and you just made me 5x more relaxed for when I go back in.
    Veteran Member Three Rings LordMagnet's Avatar
    Jul 20 2015
    Connecticut
    I called up my dealership and spoke to the service manager before I pulled the trigger on my intake & exhaust. He said he can't give me anything official in writing or make any promises, but also that he's never had any warranty issues with vehicles that have come in with aftermarket intakes and exhausts. He did say ECU tuning was a big no-no.
    2015 Audi S5 Coupe 6MT | Mythos Black Metallic : Black Nappa : Alu-Optic : B&O : Sport Diff. : 19" RS Rims : Carbon Fiber Inlay | APR Stage 2 : Roc-Euro Intake : AWE Touring Exhaust 102mm : EuroCode Short Shifter : USP Clutch Line : CR-15 Strut Tower Brace : 034 Mounts : H&R OE Sport Springs : 15mm/20mm Spacers : Tint 35% Sides / 20% Rear : Interior LED Kit : E-Codes : Vinyled Grille | 413 AWHP / 375 AWTQ
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    peekabu.. Talk to your SA before you go in.
    C7.5 S6 P+ Mythos Black
    10.894@126.29 103oct Stage 2 100 File/RACECHIP
    11.284@121.29 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 11.978@117.71 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Jun 11 2014
    Ny
    Not sure which intake I have, I think it's eurocode ?
    My service adviser is Cory , he's prety cool. Also if you take care of him on the survey,it's more likely he remembers it.
    Jan 09 2008
    Winnipeg
    My SA said no to getting an intake but gave me the green light for a short shifter...sway bars were a grey area.
    Veteran Member Four Rings jokingjimmy's Avatar
    Oct 20 2014
    Mk2 TTS Raodster Scuba Blue
    Pittsburgh, PA
    Quote Originally Posted by LordMagnet View Post
    The question is simple. Ask your service manager (not the SA) if they will or will not manually flash you TD1 for an intake (exhaust too if that's a concern). All this above posted stuff is canned response.
    Everything graciously mispelled by Apple
    Current: 2013 TTRS Suzuka Grey
    Also: 2011 TTS Roadster Scuba Blue
    Previous:
    2014 S4 6MT Nogaro Blue Pearl
    2016 TTS Sepang Blue
    2013 A5 Midnight Blue
    2013 VW GTI DSG Grey
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    My rule of thumb is if it's just routine Audi Service to take it to a reputable third part place. I only have ever taken any of my cars to the dealer for warranty related work. Otherwise the service they perform is really no better and often more pricey. Had no issues overall.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    +1 on going to an indie shop for servicing not covered by Audi. I learned that lesson after my first $250 oil change on my B6.
    Return your car to as close to stock as possible before bringing it to the dealer; swapping out an intake is a 20-min job. The tech can manually flag you without the SA knowing about it.
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    This, for sure. This is what I did. I talked to my Dealer Criswell, and they said they don't care about them. But if they can prove that part caused the failure then they won't warranty it. Like exhaust noise or damaged s/c rotor blades.
    But honestly it takes like 20 min to swap the factory intake back on. I have intake and exhaust and every time I go to the dealer I put the factory air box back on. Its easy enough to not have to worry about it.
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    My SA in Atlanta is ok with sway bars, AK, intake and exhaust. Told me to to always bring it in "stock" <wink> for other mods and to give him heads up via phone call first so that he can schedule me with certain techs.
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    Veteran Member Four Rings amz's Avatar
    Apr 29 2013
    Ottawa
    If your dealership is cool with mods then they should be ok with an intake. That being said, I always swap back to my stock intake just in case Audi asks them to send pictures. It takes 20 beer-minutes to swap intakes so it's not a big deal.
    2012 S4 ~ Phantom Black - Mustang Brown - B&O - Sport Diff - DSG
    AWE Touring Exhaust | Roc Euro Intake | Eurocode Alu-Kruez | Eurocode USS Swaybars & Solid End Links
    Canada: the land of Quattro
    Oct 14 2012
    Empty...for now...
    SE PA
    For whatever it's worth - I recently noticed an unusual, brief sound when starting my car after it sat for 4 days. It has a CTS Turbo intake installed. I looked under the hood and did not notice anything out of the ordinary (it was nighttime in a not-well-lit parking lot). I proceeded to drive the car home on mostly freeway where I would typically see ~25mpg displayed on the DIS. During this drive I was seeing ~20mpg. The next morning I had another freeway drive where I would typically see ~25mpg and again realized only ~20-21 mpg. When I arrived at my destination I opened the hood and found this:
    That's the original intake filter that came with my CTS Turbo intake which I ordered in March 2015 and have used on the car for less than 10k miles. There are areas of the filter that have apparently deteriorated and are now missing. I'm bringing it up publicly only because I sent an email to CTS two days ago and they have not yet responded. To me, when an air intake manufacturer has a clear defect with one of their air filters, which is a major component of their system, responding to that issue should be top priority.
    Anyway - the reason I bring this is up is that if you are going to leave your aftermarket intake installed when taking the car in for service, at least do a thorough inspection of it to make sure everything is intact and connected properly. I would understand Audi issuing a TD1 for a car with aftermarket intake having holes in the filter element.
    EDIT - BTW, upon discovering the issue I promptly swapped the stock intake back into the car. Fuel efficiency appears to be back to normal. Supercharger whine is nonexistent.
    SOLD 2015 Daytona Gray S4
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Quote Originally Posted by SteveYem View Post
    That's a little scary. I can only assume that little pieces of intake media were sucked into your engine?
    Veteran Member Three Rings brainpan's Avatar
    Apr 11 2010
    sk8 banana
    ontario
    Yikes... I've had a cts intake for a little over a year now haven't noticed anything like this with the filter. Did you wash it with any sort of chemical? I have a spare filter but just washed the original one before winter. I'm definitely gonna check on it now seeing those pics.
    Sent from my Note 5
    Bryan
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by jsh139 View Post
    Presumably so.
    Quote Originally Posted by brainpan View Post
    Sent from my Note 5
    Nope, in fact I have not cleaned the filter at all. It has been installed on the car for only ~10 months / 9000 miles, so nowhere near a service interval.
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    Presumably so.
    You should contact them, their customer service with me was top notch!
    Aug 23 2014
    Philadelphia, PA
    We looked into this and the guys over at CTS already are on it and said it was replaced under warranty
    Jul 21 2004
    South Florida
    Presumably so.
    Interesting. You may want to add to this post here Steve...
    http://www.audizine.com/forum/showth...Is-this-common
    I hope this isnt a widespread issue. Can other people check theirs and see if this is happening?
    Mike
    2018 Audi S5
    Gone-
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    There was a document posted on here once before and it listed intakes and exhausts as TD1 items. But as others said its up to the dealer to put it in they system.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by B18b1ex View Post
    Quote Originally Posted by ModdedEuros View Post
    Correct, I heard from them shortly after posting this. In hindsight I regret having posted this since they are resolving the issue, but it still stands as a relevant point to this thread re: aftermarket intake vs. warranty.
    Jan 10 2014
    San Antonio TX
    To contribute a bit more to the thread hijack. Everyone with an aftermarket intake should check it periodically. I had the EuroCode intake and discovered the bolts that connected to the factory airbox had pulled through the plastic on the filter.
    Oct 20 2014
    Pittsburgh, PA
    Nope, I think what you did was just right. You didn't slam CTS, you just showed something that should be a concern for all of us that read this forum. It's the reason for the forum, (although some would argue it's for flame wars, ego boosts and selling product lol). The distributor and then yourself came back and said the issue was resolved by CTS, so it's a perfect story for in here. Now everyone will check their filters to ensure it's ok :D
    Quote Originally Posted by Motown_Dub View Post
    Yep, I do this often too. I always wonder if the oil will evaporate when I slack on checking it, then the dried out filter would deteriorate, so it gives me peace of mind to check it (once a month at the C&C LMAO).
    Previous:
    Mar 21 2015
    So have they upgraded the filter at all or do you get the same crappy filter?
    Aug 03 2014
    Queens
    Personally .. I wouldn't name no SA's or dealerships on here.. You never know when AOA might poke around. That mod friendly dealership might become mod unfriendly.
    Keep the info through PMs just in case.
    If your going to a dealership in LI, PM me.
    Previous
    Oct 14 2012
    Empty...for now...
    SE PA
    I presume that the replacement filter will be the same type/quality as the original, but I do plan to buy a spare filter from someone like K&N or AFE (or anyone else that someone could highly recommend).
    Jul 02 2004
    FL
    From my understanding the B6 and B7 S4's had warranty issues with intakes because oil on MAF sensors, as these engine don't have these it is not a part that will void any part of your warranty.
    Mar 21 2015
    Wrong, they can manually flag you for it now.
    Jul 02 2004
    FL
    If it's damaged, or just because it's present? Not sure that will hold up as you can't be required to use their filters and the housing is solely for noise control.
    Mar 21 2015
    When the CAI is present at the dealer. Someone posted a dealer letter stating they can flag you for TD1.
    Sep 18 2013
    Mercedes C300
    New York City
    can anyone help me find the DIY post on the B8 forum that showed step by step on how to install the CTS intake? I need to reverse install and put my stock intake back on for servicing.
    Mar 21 2015
    Quote Originally Posted by peekaBu View Post
    Really? Vid at the bottom or check out roc euro for manual, very similar.
    http://www.ctsturbo.com/cart/product...-3410-116.html
    Edit
    Did it for ya
    http://roc-euro.com/downloadable/dow...5MDk5MTU1MTA3/
    Sep 18 2013
    Mercedes C300
    New York City
    the video is out of focus and the technician installing it is blocking the view for half the video. but I will check out roc-euro manual. thank you.
    Veteran Member Four Rings Gusman1's Avatar
    Jun 01 2014
    2018 BMW M2
    San Jose, CA
    I just installed my cts intake last night. I used both the video and the roc euro guide. I found out that if you remove the scoop that feeds air into the intake, it's a lot easier to install the heat shield. Oh and it was bitch to remove the rear hose that connects to the intake tube.
    Allroad
    Jul 16 2012
    Mid-Atlantic
    Quote Originally Posted by Gusman1 View Post
    The easiest way I found to get the vacuum hose disconnected (without using a metal pick that could pierce the hose), was to take a wooden kebab skewer and roll the pointed end between the inside of the hose and the the vacuum nipple while pulling. That plus fully disconnecting everything from the stock breather tube allowed me to get some leverage while pulling.
    2014 S4 - APR Stage 2 - APR CPS - AWE Touring w/ Resonated Downpipes - APR Carbonio Stage 2 Intake - Alu Kreuz - H&R Front and Rear Sways - 034 Inserts - Focal KX165 + Audison Bit4.9 + Audison 4D - Xpel Front End Wrap - Modesta BC-04 Paint Coating - Rayno S9 Tint - R8 Oil Cap - Porsche 911 Coolant Cap - CR15 Strut Tower Brace - Q5 Brembo Brakes - Goodridge Stainless Brake Lines - P3 Gauge (w/ Track Pack)
    My Seller Feedback Thread - http://bit.ly/2vD36PE
    Mar 10 2015
    New England
    I had the same issue. Someone mentioned that it is much easier to remove when the car is still warm after driving.
    Jun 01 2014
    2018 BMW M2
    San Jose, CA
    Quote Originally Posted by Works2shoot View Post
    I used something similar that I found laying in the garage. But I did notice that when I inserted the hose to the extension piece coupler the hose wasn't as tight, so I put a zip tie to make sure it didn't go anywhere.
    Quote Originally Posted by The Fat Kid View Post
    Yeah this would of probably made it easier.
    Allroad
    Veteran Member Three Rings shoe3k's Avatar
    May 18 2015
    weedwhacker
    No where
    Never take someone's word when it comes to YOUR vehicle and its warranty. A manager or technician will tell you what you want to hear and if it isn't in writing then it is still a huge gamble. Sure, there are managers and technicians that do not care about intakes, exhausts, or suspension mods but the same people won't always be working on your car. If you are really worried about the the manual TD1 flag just put the stock intake back on or take it to an independent shop for service.
    http://www.vwroc.com/forums/topic/83...-this-morning/
    According to this, if a technician asks about what modifications have been installed on the car there is a good chance that the Audi database has already flagged your car with a TD1.
    Previous: |'18 Golf R | '17 S6 | '15 S4 | '15 STI | '12 GLI Autobahn | '08 Passat | '04 R32 | '05 GTI 1.8t |
    Senior Member Three Rings KAMP's Avatar
    Sep 18 2018
    2004 Nissan Murano SE AWD
    Bringing an old threadback to life... I have a 2016 stock S4 with remaining warranty until July 2019. I’m planning on putting in the CTS intake as well. I would only be seeing the dealer if any warranty work needed to be done, so I guess I’d put the stock intake back on just in case.
    Otherwise, once the warranty is up in July, would the Audicare also be affected with just an intake if I brought it in? I have two services left and I plan to take it in at the end of this year and next year for the remainder services.
