Thank you all for your input; very useful discussion. I'm still waiting to hear back from the dealer...
Originally Posted by
Dippy
I have to agree that the difference is not "staggering" but it certainly is noticeable between dynamic and comfort. My passengers notice the difference and none of them are petrol heads.
However I'll throw an idea out for discussion: I have always assumed that ADS 'auto' is not automatic at all, rather it is simply somewhere between dynamic and comfort. Audi's terms are a bit vague aren't they, hence in some places the word 'balanced' is used. Anyway a while back I had a discussion about this with an RS5 owner who stated that the suspension on that car is truly dynamic in that it changes based on sensors to adapt to diving style. Now I know that the RS4/5 and S4/5 suspensions are different but Audi have used that description for the S4/5 adaptive damping. I was sceptical and believed that when my ADS 'individual' has suspension set to 'Auto', that just means it is set to 2 in the range 1 to 3, and I just switch to ADS dynamic when I want some fun and have all the kit working to performance. However now after 9 months of ownership I am less sceptical about it. I genuinely feel that whilst in 'Auto' my dampers do tighten up due to my driving style. As such this makes the difference between my 'individual' mode and 'dynamic' mode less obvious, whereas changing to 'comfort' makes the ride horribly soft.
Now if this true, and its still a big IF, maybe it explains why the OP is not sensing the difference as much.
It took me a while to really understand the benefits of dynamic steering, but I guess that its because it has taken me a while to be prepared to push my extremely expensive S5 to the limits!
That's possible but just to make sure that I see a difference I've been switching back and forth from comfort to dynamic.
Woodybangs
If you don't have shit roads then the difference will be harder to notice. The comfort setting allows for less jarring over crap roads here in Michigan. I notice a much stiffer ride in Dynamic mode.
Trust me, roads are pretty shitty in Quebec in the Winter ;)
amz
They make a huge difference for my '12 S4 in cold Canadian winters. I've re-coded my car to start up in Individual mode so my car starts up in all comfort mode for the winter, and a mix of auto/dynamic in the summer (suspension goes to dynamic.)
Scout out a moderate bump or pot hole in the road near your dealership and drive over it in comfort then dynamic a few times. Then take an S4 with ADS from the lot and do the same thing, you should definitely notice (read: hear/feel) the difference between Comfort and Dynamic, but you shouldn't notice a big difference between your car and one from the lot. If you can, then something is wrong. If you have non-OEM rims on, put the OEM rims back on...I almost guarantee they will try to blame it on rims if you're not sock.
Good point. I do have OEM rims on 18 for the Winter but I don't remember seeing any more difference with my stock RIMS and 19...
