Results 1 to 27 of 27
    Established Member Two Rings rtk8892's Avatar
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    Huge problems after removing ecu... PLEASE HELP
    Hello I have a b6 s4, jhm 93 tune. I have been getting an eeprom error with vagcom so I called jhm Motorsports and the gentleman instructed me to remove the ecu, then call back with the numbers on the inside. I did so, then called back, he had me further disassemble and completely take it apart revealing the green board. I was extremely gentle. Reassembled everything, I also took out each relay down there and looked at them then reinstalled them. Everything is now put back together and when I put the key in and start it starts for a brief second then immediately shuts off. I ran for codes and go every damn code in the book there's tons of them. I don't know where to begin. Should I unhook both battery cables and touch them to reset the ecu? Please please please help
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    No one?
    Veteran Member Three Rings jr1415us's Avatar
    Mar 08 2011
    Chicago IL
    I think JHM should be the ones to help, since following their instructions brought this problem on.
    2013 Arctic White Allroad Premium Plus
    RIP 04 S4 Avant 2012-2017
    Feb 13 2004
    AW E30 M3 & PB B7 RS4 (DD)
    You may need to clear a code for immobilizer
    Look at a few threads before: "Need help with Resetting either Immobolizer or the Cluster!"
    Nov 12 2015
    Oregon
    Yeah it sounds like the immobilizer could be stopping the engine. Can you clear the codes and try again?
    My build log
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    I actually tried that and it didn't work. This sucks!
    Nov 12 2015
    Oregon
    Did they give you any indication as to why this happened or what caused it? I'm getting ready to have mine tuned. ..
    My build log
    Veteran Member Three Rings 0396's Avatar
    Feb 10 2005
    L A
    Quote Originally Posted by jr1415us View Post
    Yes, call the outfit that advise you to perform task
    0396
    Veteran Member Four Rings xhackerekx's Avatar
    Jul 23 2007
    10S6C6_12Q7TDI_A4B6 3.0_VNL730
    Scranton , PA / Poland UE
    This is u oem ecu ?
    Established Member Two Rings nogaroblu's Avatar
    May 10 2015
    Chicago, IL
    I just had the same problem, it started and ran for half a second to a second and shut off. I needed the Immobilizer, Cluster, Keys, and one other thing reprogrammed. Cost me $400..
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    Yes it is, but it has the jhm 93 octane flash
    - - - Updated - - -
    Quote Originally Posted by nogaroblu View Post
    Is it possible to do the reprogram with vagcom
    Jul 23 2007
    yes u can just u need know car immo pin , when u live around my area I need 5 minutes for this.
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    I called jhm, the guy doesn't believe it's the immobilizer he advised me that the fuel pump may or may not have gone bad. If it were the fuel pump though, wouldn't it not start at all?
    Feb 10 2005
    L A
    Quote Originally Posted by rtk8892 View Post
    They advise you to perform task, now they are not accepting any responsibility? ??. Oh yes it could be the fuel pump, but if its not. ......
    0396
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    if it would be a fuel pump, car wouldnt start at all... or crank for a long time then start but it wouldnt die suddenly. it would take some time for it to die.
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    immobilizer will make your engine shut down quickly, just like turning the key does,
    with a fuel pump failure, your engine will definitely miss/burble/run bad/whatever before stalling.
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    I can hear the fuel pump when I turn the key to the on position, and it is showing all signs of the immobilizer... I just don't get the dash light while trying to start it. All I want to do is drive my car!
    Feb 13 2004
    Exactly like Lucca said: when my fuel pump went out on my B5, no start at all.
    Nov 12 2015
    Oregon
    a fuel pump could be likely, however if the problem presented itself right after removing and reinstalling the ECU, there is a good chance the IMMO needs to be "reset" (correct term?) If you scan the car now, do you get "immobilizer prevented the vehicle from starting" code?
    My build log
    Senior Member Two Rings willroc7's Avatar
    Sep 04 2014
    JHM doesn't know wtf.
    Edit: Another vote for immo.
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    Yes I do get that code abt the immobilizer. Can I reset it myself with a vagcom
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    Also, is there any possibility that maybe I bent one of the prongs on the ecu plug while plugging it back in? I'm getting a ton of other codes that were not there prior to me removing the ecu. A few examples are air intake temp sensor, maf sensor, power supply terminal 30 too low, abs controller, power train data bus, engine control module sproradic and a ton of others
    Nov 12 2015
    Oregon
    im sure anything is possible. Have you cleared the codes? (not the simple obd2 codes in the generic settings) I just don't see how unplugging it and plugging it back in could cause it to not work and cause a bunch of other codes that were not present before.... unless there is something else going on there.
    i was going to purchase a used "tuned by JHM" ecu from someone here. He claims that the ecu can be coded to the IMMO through vagcom the same as if you just replaced the ECU. Maybe someone can expand on this?
    My build log
    Established Member Two Rings RedS4avant's Avatar
    Jun 26 2015
    Way out in the sticks, BC
    Have you reset the immo code with vagcom yet? From reading through the thread it sounds like you still are yet to clear code with vagcom and attempt to start car again.
    If you have tried this already my bad, just be how I read it
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    Quote Originally Posted by VinnysS4 View Post
    Yes I have done a complete vag scan, I use a foxwell nt500 and I have cleared all codes with vagcom. Nothing. The worst part is that the closest Audi dealer is 2+hours away. A tow there is gonna be a hefty price
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    So I pulled the ecu back out, the prongs were good. There's a 40amp fuse under there and it was blow. I put a new one in reinstalled the ecu then hooked the battery back up. The car started and ran kind weird, I did another vagcom scan and still got all the same codes. I shut the car off, then tried to start it again and same thing. It started then immediately died, and now when I try to start it, it turns over slow, then starts clicking. Any ideas? Please I feel stuck
    Nov 12 2015
    Oregon
    battery is dead
    My build log
