Results 1 to 9 of 9
    Established Member Two Rings BB c7's Avatar
    Jan 23 2016
    Chicago
    How to get a power to 12V Power Outlet When Ignition is Off?
    I've noticed the 12V power point shuts down when the ignition is turned off. Is there a setting to keep power to power outlet at all times?
    I don't want to turning a car on every time when i need to use power outlet.
    Audi a6 c7
    Thanks.
    Established Member Three Rings fatherdeath's Avatar
    Jul 20 2016
    2016 Honda CRV EXL, 2006 Dodge 2500 laramie mega cab, 1974 Buick apollo
    Tampa, FL
    Looking for this answer too since my phone stays in my car i hate coming to check my phone to find out it has died
    SOLD:2017 S6 Mythos Black Arras Red interior all the Wayne tech gadgets, RocEuro, EPL stage 1, 15mm front/20mm rear spacers, Eurocode Sways, end links, billet mounts ALL
    American enjoying the autobahn
    Veteran Member Three Rings tenspeed's Avatar
    Dec 13 2011
    Honeoye NY
    There is power available in the instrument panel passenger side fuse box on my 2012 A7. The top row is hot all the time and the bottom row is ignition circuits. I have my dash cameras powered from there. You could install a power outlet in the glove box (I think there's room) and power it from the top row.
    The only danger is if left on for an extended period, it run run the battery down. The dash cams are fed power from a Power Magic Pro (seen above the fuses) which disconnects the cameras when volts drop to 12 or 12.5 VDC. You can also set it to disconnect after a period of time - 6/12/18/24/36/48/72/120 hours.
    2012 A7 3.0T Prestige, Ibis white/Nougat/Ash, 20" Sport, ACC, LED, HUD, Ferrada FR2 wheels, AWE Touring exhaust, Adam's Drag II rotors, BlackVue dash cams
    As I've grown older, I've learned that pleasing everyone is impossible,
    but pissing everyone off is a piece of cake
    Mar 26 2010
    US
    Quote Originally Posted by fatherdeath View Post
    It's a safety feature, for in case one plugs in a Samsung Note 7.
    I think some custom wiring will be involved to make the 12V Power Outlet hot all the time. I have found this to be an issue also, must have ignition or accessory mode on (which times out).
    2019 RS5 Sportback
    Jul 20 2016
    Tampa, FL
    Yeah i just want to charge my phone via a 12v while my car is off and I'm at work right now I'm using a large battery pack to keep it topped off with my apple watch
    Veteran Member Three Rings scott99c2's Avatar
    Oct 11 2014
    Nashville, TN
    Quote Originally Posted by tenspeed View Post
    Any clue which ones are battery vs switched on the drivers side? Naturally, I ran my V1 cables over there before I knew that.
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Funny... Back in 2007 my Audi had the acc outlets on all the time and people complained cuz their radar detector's had to be turned off manually or had go disconnect their chargers before they left and now it's the opposite. Guess to each his own.
    I'll have to double check but the radio power is typically hot all the time on Audis. If you have a DMM (volt meter) it would be really quick to find
    Established Member Two Rings ArizonaA6's Avatar
    Jul 31 2016
    WA
    I just installed a dedicated USB charging cable in my S6. I wanted constant power as well. This is my setup.
    Oct 22 2014
    Atlanta, GA
    I plugged in a add-a-fuse on A/3 (CD/DVD Changer) thinking it was switched, but the 12v-5v buck converter drained the battery enough over 24H that I had to jump start. Need to do some more testing.
