Results 1 to 3 of 3
Thread: ABS lights on
    Dec 06 2015
    Hawaii
    ABS lights on
    03 B6 Avant Quattro, getting a "right rear ABS speed senor" code.. looking for a replacement but cannot for the life of me figure out if I need the auto dynamic headlamps version or not? I'm thinking this dynamic headlamps option is because of the Avant or Quattro model but there are also some for base models on RockAuto. The only help I've got from searching is that most of these issues are solved solely from having the ABS module rebuilt and that it's usually not the wheel sensor at all. Any input would be great, thanks.
    May 12 2010
    lowell, Michigan
    I have a bosch in perfect condition if you need one. PM me for details. Did you run a vag yet? Make sure you do or you'll be replacing a perfectly good ABS sensor for no reason. If you end up seeing code 18265 with a sub-code of P1857 just below the ABS Wheel Speed sensor code 00-287 its not the sensor, it's your MAF.
    Cheers,
    James
    Feb 03 2015
    United States
    I replaced my sensors to no avail. Just had my abs rebuilt. Worked like a charm.
    Sent from my SM-G920V using Audizine mobile app
