list of stuff i have but not installed , please let me know if i have this wrong
•Jhm Motorsport ; B7 Rs4 stage 4 kit (240mm) with kevlar on pressure plate side & custom 9lb flywheel , made for the b5 1.8t
•IE Forged 144x20 rods
•Snow Performance Stage 3 Water/Meth kit *
•Chevy 454 injectors made by bosch ( 760cc @ 3 bar , over 880cc at 4 bar according to injectors dyne sheet )
•GTX2971R , billet compressor, arp hotside housing
•Front Mount Intercooler & piping
•CTS Turbo Fuel Rail
•Aeromotive Fuel Pressure Regulator
•0/100 psi Fuel pressure gauge
•6/8/10 an fittings and hoses*
•Catch Can & IE block breather 10an adaptor & weld on bong for Valve cover
•Power Steering Cooler*
•Lightweight Pulley set*
•IE Adjustable Cam Gear*
•IE Manual timing belt tentioner kit & metal propeller water pump
•Racing headers*
•Headers Wrap
•4’’ mass air flow custom sensor housing if im not going stand alone
•bigger turbo inlet hose*4"
New stuff added to the list -->
•Arp crank main studs
•Arp head studs
•bigger intercooler vibrant 18215
3" in/out 3-1/2" core
• intake manifold spacer for cooling
Stuff already done*
•Walbro 255 Fuel Pump
•new style coil pack Conversion
•R8 coil packs*
•.044 regap plugs
•stag2+ unitronic 94oct
•A8 front disk , tt carrier .. complet s4 rear swap
•Evo Motorsports Dv valve*
•St coilovers
•Rs4 Wheels
Stuff i still need*
•3’’ full turbo back *
•Rear handbrake cables & install*
•Manual Swap 01A 5 speed*
•Rod Install + crank bearings + piston rings + crush washers + 20mm wrist pins
• figure out what im doing , stock ecu or standalone
•Dyno tune
I still need help figuring out these things abd need help please
• 75mm or 80mm drive by cable trottle body
• stock ecu or standalone .. If standalone , i want aeb , need more info on this
I beleive standalone is my best way to go for this aeb car , tell me more about harness and how this all going to work with the stock cars inside equipement
