Results 1 to 40 of 43
    Senior Member Two Rings AWD Addict's Avatar
    Nov 06 2013
    Livermore, CA
    leaving behind a cloud of smoke at stoplights
    Lately I've been noticing that if the car's at running temperature and I've been sitting a few minutes at a light, when I drive off again I'll look in the rear view and see a healthy cloud of exhaust. Wondering if this is normal for a cat-less RS4 running a full exhaust and a 91 octane tune?
    Jun 25 2009
    07 RS4, 91 BMW 318is
    SC
    No, it's not normal. Ever changed your PCV?
    Nov 06 2013
    Livermore, CA
    I've never replaced it.
    Jun 25 2009
    SC
    I believe FWP was having the same symptom and a new PCV was the solution.
    Nov 06 2013
    Livermore, CA
    thanks komseh
    Account Terminated Four Rings Quattrors4's Avatar
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    Quote Originally Posted by AWD Addict View Post
    thanks komseh
    spray the inside of your pcv oil seperator with carb clean or soak it in fuel for a few hours,should fix it,those separators are expensive like 300$ i think
    Jan 14 2009
    Audi's
    I had this issue when my valve stem seals / guides failed ..... I know its more common of the BHF S4 engine. I've never heard of it happening with a RS4 so hopefully its just your PVC.
    Veteran Member Three Rings NYC_Legacy's Avatar
    Oct 14 2009
    AZ/NY
    Quote Originally Posted by komseh View Post
    I third this, friend and fellow owner was experiencing the same symptoms. PCV was the fix.
    "Brake last, finish first."
    Nov 06 2013
    Livermore, CA
    Quote Originally Posted by Quattrors4 View Post
    When the car had a carbon clean about 5K miles ago we also installed JHM's Oil Separator Heater Bypass. Is that a different part?
    Active Member Four Rings BenSti's Avatar
    Nov 03 2010
    Cupertino, CA
    Yeah, normally coolant flows through the oil separator, the JHM setup just bypasses this making the manifold easier to remove. The separator is a black plastic piece in the back of the manifold.
    2008 Audi RS4 Ibis White w/ Ti Package | 18x10.5 TCIII w/ 275/35 NT01 | PSI Raceline Ohlins | Stoptech Trophy Brakes F/R | Raybestos ST47 | OSGiken 1.5Way Rear LSD | Wavetrac Front LSD | Apikol Diff Mount | 034 Billet Subframe Bushings | 034 Motor Mounts | 034 Aluminum Trans Mount | 034 Spherical UCA | 034 Front Endlinks | JHM LWFW&Stage 4 Clutch | JHM Shifter+Linkage | Custom CAI | Custom Splitter | Hotchkis Sways F&R | Status Ring GT Seats + Half Cage | 034 Rear Endlinks | EBW LW Battery
    Jun 18 2009
    Phoenix, AZ
    A new PCV lessened the smoke, but it was definitely still there. I'm thinking it's the valve seals because it's still doing it, getting estimates from some shops to see how much it would be to replace them.
    2017 Camaro SS 1LE
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Avant Abt AS400 clone, 14 SQ5
    Sunny UK
    It definitely sounds like it's blown. I'll buy it for $3.50 and can pull it myself.
    -Tim
    Nov 06 2013
    Livermore, CA
    Thanks FWP. A bad PCV can lead to bigger things if left unchecked so I need to get on this. Is it accessible on our engines or does it involve intake manifold removal or the dreaded $ervice mode?
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    It is possible to replace the PCV valve without removing the intake manifold but the secondary air injection hose is in the way and a bitch.
    Jun 18 2009
    Phoenix, AZ
    Yea as JimmyBones said, it's not easy. I've done it probably 15 times now so it takes me 1 hour from start to finish swapping the PCV out, but you do have to loosen and then move the SAI tube out of the way enough to get the bottom torx bolt bolting the PCV valve to the intake manifold.
    2017 Camaro SS 1LE
    Nov 06 2013
    Livermore, CA
    Ok good to know. Is there a way to test the PCV for problems before I make the effort to remove it? I'd hate to do all of that and it doesn't fix it.
    Jun 18 2009
    Phoenix, AZ
    I have a new theory..
    So I get the smoke after idling for a while and then taking off, but it only happens maybe every 1 or two weeks where it'll do it once, and won't do it again for a long time.
    What if it's a sticking injector? The injector sticks open, washes down the cylinder, and then when I take off, all of that gas and oil gets burnt off? The smoke has always smelled slightly like burning oil, but A LOT like the engine is running REALLY rich. Reminds me of when I had an injector go bad on an old car of mine.
    I need to find some time to get my injectors sent out to have them cleaned and flow matched.
    2017 Camaro SS 1LE
    Nov 06 2013
    Livermore, CA
    Sounds like a good theory. Seems pretty consistent with everything I'm experiencing too. I'm not getting smoke every time I cold start the car or every time I pull away from a long light. Was in Tahoe last weekend and I never saw it happen once.
    Jun 18 2009
    Phoenix, AZ
    I got 6 of my injectors out and took them to a shop I found in Phoenix that does cleaning and flow matching for FIS injectors. I tried getting the last 2 out, but they were nearly welded in place and ruined them getting them out, so I have two on order from rockauto that should be here tomorrow, then I'll take them over to the shop so that all 8 can get flow matched and also so we can compare new injectors to my OEM's. They're also giving the fuel rails a bath in the ultrasonic cleaner. Looking forward to getting it all put back together to see how she runs.
    2017 Camaro SS 1LE
    Jun 25 2009
    SC
    FWP, do you have buildup in your fuel rails or something? Or just getting them cleaned for sake of completeness?
    Jun 18 2009
    Phoenix, AZ
    There was a very slight "grey-ish" film we saw on the inside of them and they're doing them free of charge so I figured why not.
    2017 Camaro SS 1LE
    Nov 06 2013
    Livermore, CA
    Looking forward to hearing the results FWP!
    Jun 18 2009
    Phoenix, AZ
    Report for the 6 OEM injectors. They said #2 was leaking and wouldn't hold pressure initially, but it was ok after cleaning. Could be the cause of my issue. Will put it all back together tonight.
    2017 Camaro SS 1LE
    Nov 06 2013
    Livermore, CA
    Notice any difference yet?
    Veteran Member Three Rings Seattle squash's Avatar
    Jan 27 2013
    B7 RS4 + BMW E92 328i (modified a bit more)
    Just did mine, and way less smoke! Will watch oil consumption as well!
    Jun 18 2009
    Phoenix, AZ
    No smoke yet, car runs great, even "smells" better. Only driven about 50 miles, so I'll report back in a few weeks. Hoping the cause was a leaky #2 injector.
    2017 Camaro SS 1LE
    Nov 06 2013
    Livermore, CA
    Cool. I'll be crossing my fingers!
    Senior Member Three Rings Striddy's Avatar
    Jul 15 2011
    nothing but memories
    What ever happened with this?
    Ghost
    Jun 18 2009
    Phoenix, AZ
    Quote Originally Posted by Striddy View Post
    It's been a few weeks since I did my injectors and no smoke at all. The car runs better, starts quicker, doesn't "stink" as bad (catless downpipes). I think it was my leaky #2 injector that was causing the issue.
    2017 Camaro SS 1LE
    Jul 15 2011
    Quote Originally Posted by FWP! View Post
    Thank you, looks like I'll be doing the same. Was your EPC light on?
    Ghost
    Nov 06 2013
    Livermore, CA
    So I paid to have the leak down and compression checked. Everything was within the acceptable range which, I'm told, likely means it's a defect in the head that's causing the oil to burn.
    Jun 18 2009
    Phoenix, AZ
    Have you replaced the injectors yet?
    2017 Camaro SS 1LE
    Nov 06 2013
    Livermore, CA
    Mechanic said the injectors were fine. That's why we did the leak down and compression tests first.
    Jun 25 2009
    SC
    How does the mechanic KNOW the injectors are fine?
    Veteran Member Four Rings your daddy's Avatar
    May 29 2007
    NOW-17 R8 V10+,08 RS4/Ti/AE,2021 S6, THEN-08 ibis TI,02 337, 01 S4, 92 gti vr6,90 corrado, +many
    Billerica/Lexington,MA
    crystal ball
    Rick autoengineering.com @autoengineeringlexington
    -APR-Integrated Engineering-JH Motorsports-034 Motorsport-ECS tuning-Forgeline-CTS, plus many more
    Nov 06 2013
    Livermore, CA
    He said there would have been a significant loss of pressure
    Jun 25 2009
    SC
    I'm not convinced a leakdown test is going to reveal leaking or poorly flowing FSI injectors. I may be thinking about this incorrectly so someone please correct me if I'm wrong.
    If I were you I would replace or clean the injectors. It's a lot cheaper than going down the path the mechanic suggested. You could do it next time you carbon clean to save on the labor.
    Guessing games are no fun on the wallet when it comes to repairing cars, but in this case it's an educated guess since you are having identical symptoms to at least one other forum member. It's also a member that went through just about all the possible fixes for the symptoms before targeting the injectors.
    Nov 06 2013
    Livermore, CA
    What the fuck did I just pay $400 for then?
    Jun 25 2009
    SC
    Well, you know your motor is in good shape. The compression and leakdown numbers came back good, right?
    Nov 06 2013
    Livermore, CA
    Yes the tests showed everything was in the acceptable range. Maybe I was asking the wrong questions. He couldn't give me a print out so we talked through the results and what it could likely be.
    FWIW I'm not using up a lot oil. In fact I would say it's the exact same consumption rate as it was BEFORE the blue smoke.
