3.0 B6 Tip trans, on cold start up it sometimes will whine very audibly, and sometimes it won't. I know its not power steering because the fluid is not low and its not the same noise. Once the car warms up, it does not make the noise at idle, but when you start driving even at low speeds the noise comes back. I also have the red oil pressure light that does not come on until the car is at operating temp, and intermittently goes away when the engine is under load. I never have the light pop up until the car is warm or after 15 mins of driving. Is it the oil pump that's making the noise? I'll try to make a video and post it later. My dad thinks its a vacuum leak but I can't find any broken lines or anything.
