Results 1 to 9 of 9
    Veteran Member Four Rings AsianA408's Avatar
    '10 A5 S-line, 07 Sline A4, 99 A4q, 2002 S4,2000 S4, 2008 335i
    San jose, CA AXION BETA
    Transmission issue?
    Hey guys my 04 avant quat.
    Runs and drive but needs some type of work. IDK what though.
    This is the car I was using for my daily commute, The car can drive for about 80 miles with no problem, however if you stop at a light, stop sign or even if you need to stop when stuck in traffic, the car won't drive anymore. You will have to turn the engine off, give it 5 minutes and then turn it on again to keep on driving. I don't know what is wrong with the car, I'm guessing it needs some transmission work. any ideas?
    1999 audi a4q(Sold)
    2007 B7 S-line A4(current)
    2002 B5 S4 Santorin / 06 Ninja ZX-10R
    _________________________
    |.....Overnight.......................|.|\
    |........PARTS FROM........-....|.|||";,__,
    |_...__...JAPAN_______=====|.|_|..|...|
    "'(@)'(@)""'''''''"'''''''l''/(@)(@)*****(@)"
    TEAM|AXION
    "Are you a good sticker putter?" - Dino/S-POWER
    Oct 02 2006
    Wadsworth,OH
    What exactly do you mean it wont drive anymore? Like you give it gas and it just revs or it locks you out of gear? Does your gear selector light up all red when you come to a stop?
    Need some more information.
    Jason
    The car dies and basically sits in limp mode. I cannot start it. I let it sit for 5 mins and then fire it back up. then it drives for the allotted time / miles again.
    1999 audi a4q(Sold)
    TEAM|AXION
    Oct 02 2006
    Wadsworth,OH
    Likely have to scan the car to see what codes are popping up.
    Jason
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    If the engine dies, it's likely not a transmission issue. Could be a sensor going bad or a vacuum leak. Like Jason suggested, try to get a scan done of the ECU to give you a starting point.
    USP CLUB MEMBER #34
    Veteran Member Three Rings tHatOne guY's Avatar
    Aug 20 2012
    06' Yamaha R1...Raven
    Mesa, Az
    Quote Originally Posted by CyberPMG View Post
    Transmission torque converter staying locked up at a stop light/sign will kill the engine.
    If that is your problem you should have a code for the torque converter clutch or solenoid.
    I assume we're talking about an auto box.
    Feb 23 2004
    Stow, OH
    Quote Originally Posted by tHatOne guY View Post
    Good point, but the OP never mentioned if this is a manual, Tiptronic, or CVT transmission in his car.
    USP CLUB MEMBER #34
    Veteran Member Three Rings Audi body's Avatar
    Jan 03 2013
    bike and a pit bull powered pair of rollerblades!!
    the woodlands tx
    If a manual it could be the crank position sensor. I had very similar issues.
    Veteran Member Three Rings msharifi's Avatar
    Aug 13 2008
    Orange County Cali
    Quote Originally Posted by AsianA408 View Post
    If you have Tip the next time it turns off turn on the car and move it to the tip and see if you are stuck on gear 3-4 mine locked up at stop and leaving the drive way turned on the car and was showing it was on gear 3. I had a bad torque converter. Since I replaced the torque converter 43K miles ago I decided to just sell the car :( I know sad...
