Originally Posted by
das4
I completed my swap about a month ago. I haven't done any of the recoding yet as I need to either buy the VAGCOM cable or find someone locally with one. Before I do, I'm looking for some insight if anyone has some. Here are the specifics:
1) I installed an RS4 cluster, which SHOULD have been preset for manual since that's the only way they were made, correct? I was under the impression most of the recoding is for the cluster so it knows where to pull info from. Please correct me if that's wrong.
2) I cut and removed the wiring plug that used to connect to the valve body on the tip trans.
3) I removed the TCU completely from the car.
4) I did not reconnect the brake pressure sensor on the side of the brake fluid reservoir as I'm under the impression 6 speeds don't have that.
5) I also disconnected the sensor on the vacuum canister next to the PS fluid reservoir for the same above reason.
I have an illuminated ESP light, ABS light and the flashing brake warning symbol in the center of the DIS on the RS4 cluster. What I'm wondering is, should I still need to recode the ECU/Cluster since I'm using an M-box from a 6 speed and an RS4 cluster? Would really like to get rid of these Christmas lights. Thanks to the B5 pros for any advice
First off, welcome to the tip to 6-speed swap club. I'll answer as much as I can.
A) You will still need to recode the RS4 cluster for it to work properly in your car.
A) That is fine you can either cut it or zip tie them away. Not going to be needing them.
A) Not needed good to remove it.
A) Not needed when converting to 6-speed.
6)I have an illuminated ESP light, ABS light and the flashing brake warning symbol in the center of the DIS on the RS4 cluster. What I'm wondering is, should I still need to recode the ECU/Cluster since I'm using an M-box from a 6 speed and an RS4 cluster? Would really like to get rid of these Christmas lights. Thanks to the B5 pros for any advice.
A) You will need to recode the cluster first. Then the ABS, and last the steering angle sensor G85 if, that code pops up in Vagcom. There are lots of info on the web on calibrating these items. I have not successfully cleared the ABS, traction control light, and brake light yet. I am very close though. Once I crack it, I'll post it in my build thread. Good luck to you on getting these lights off.
