Results 1 to 16 of 16
    Dec 20 2015
    New owner, Nogaro S4 build.
    Hi all I am the current owner of this car
    http://www.audizine.com/forum/showth...Nogaro-project
    My plan is to keep it 99% stock and reliable, my other car is a built mr2. It sounded like a turbo was blown and at the same time had a loud knock. No surprises here, well kind of. Is that a thrust bearing? an oil squirter or two!? Already have a new motor ready to reseal up and drop in.
    The right side turbo is shot, but the turbine side was completely dry, oil feed pipe plugged up maybe? At the same time the left side turbo is in good shape still but has a ton of oil in the turbine side. Any idea why?
    Good turbo
    Bonus downpipe carnage, I can do better than that. Anyone have the flex pipe size needed?
    Pulling the trans off next, hopefully no more bad news.
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    Haha, FAW welded that!
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    hahahahhhahahahahahahahhahahahahhahahahahahahahaah ahahahah
    weslife fo sho yo
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    Wait. Is that dp held on with a hose clamp?
    Edit. Nvm, I'm guessing its for the heat sheilds
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    FAW? I saw like two videos on youtube of him and his car and have ever since thought, wow what a guy hahaha
    Nov 22 2011
    ny
    I looked at that car when it first went up for sale by PO, That is some crazy carnage, at least the body is real clean, I believe the dp flex is 2.25.
    Dec 20 2015
    I got new flywheel bolts from JHM which looked correct in their picture but I received different bolts, I havent taken my old bolts out yet but I think I recieved the wrong ones? I did a quick search and couldnt find anything.
    what I ordered
    what I got
    Yes, I only count 7
    Senior Member Two Rings rani_aridi's Avatar
    Nov 12 2013
    B5 S4 '00 BB
    Irvine, CA
    Those look like they could be for tip torque converter. Definitely not flywheel bolts though. The web picture w blue loctite looks correct.
    1998 Tornado red VW GTI VR6 - hit a tree. Broke the tree
    Senior Member Three Rings audi-hammer's Avatar
    Aug 28 2009
    Buffalo,NY
    Joel Francisco in Newburgh, NY is parting out his silver single turbo if you need parts "close" by
    Silvia = 02 s4 stageIII
    Dec 20 2015
    Saturday, first day on the road. H&R coils on the way. Today the coolant boiled over, hopefully only because I'm a complete idiot and didn't read up on bleeding the heater core.
    Apr 27 2016
    New Jersey
    does he have any parts left
    Quote Originally Posted by audi-hammer View Post
    Veteran Member Three Rings hotshot32890's Avatar
    Dec 05 2009
    2008 VW Passat. 2000 Audi S4
    Boston, MA
    Ugh noggy always looks good in pictures....and im here just with a waxed k24 silvaro sedan
    Current:
    IN THE MARKET
    Previous:
    F21 Brilliant black b5s4
    SRM K24 silver b5s4
    Black B5S4: Eurojet Grenade DVs, AWE Twin1
    Eclipse GSX: 16G turbo
    Aug 25 2015
    Raleigh, NC
    Awesome to see that it's running again. Did you figure out the boiling over issue?
    Dec 20 2015
    Not yet, I ordered a waterpump and will take it apart and check it out. I think the heater core is half clogged I get good heat but it is a major bitch to bleed. I need to swap out the fan controller as well.
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by dvom View Post
    Grab a 5 gal bucket and water pump from harbor freight. You can cycle cleaner through it before it clogs 100%
    Dec 20 2015
    Just put a new water pump, tstat, reservoir tank and lower radiator hose o ring and the car now builds pressure. Fans still dont turn on when hot, disconnecting the switch and jumpering the pins turn the fans on low and high speed correctly, so I replaced the switch, still doesnt work... I have another connector from the junkyard harness Ill try to swap over. This car doesn't like me.
