OK so after all these years of reading everyone else's problems I have a big one. My 05 A8 has it's normal share of codes that I ignore, and more recently the immobilizer has kicked in complaining about communication issues. Now more recently it has gotten to the point to where I had to clear the codes nearly every time I start the car but today is the kicker and I realize I can't get away with this anymore. I am a DIY'er that hates taking my car in but this time I think I am destined to see Audi very soon. Below is the stream of complaints from VCDS immediately after clearing everything. Now my car is in serious limp mode! What is the common issue here? blown fuses? water in a connection? bad controller or central unit? ugggh!
Tuesday,02,February,2016,15:28:19:02597
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
www.Ross-Tech.com
Mileage: 222950km-138534mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 1D 25 34 36 37 38
42 46 47 4F 52 53 55 56 61 62 65 67 72 76 77
Mileage: 222950km-138534miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: Cannot be reached 1100
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1D-Driver Ident. -- Status: Cannot be reached 1100
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 1110
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes
Cannot be reached
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 D
Component: FBS AUDID3 H04 0140
Revision: 01404004 Serial number: AUX3Z0E0758448
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58BF3216EB194EFE69-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
3 Faults Found:
01315 - Transmission Control Module
004 - No Signal/Communication
01316 - ABS Control Module
01314 - Engine Control Module
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H08 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940448
Shop #: WSC 00000 785 00200
VCID: 234555FAE2DFDD264C-8076
No fault code found.
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 S HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 346BG057520127
Coding: 0000003
Shop #: WSC 22198 444 57436
VCID: 326BA0BEAD2544AEB7-8066
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000094364
Subsystem 3 - Serial number: 0114.12.100000000100010007˙
Subsystem 4 - Serial number: 010007˙
1 Fault Found:
01310 - Level Control System Control Module (J197)
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 C
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000061022
Coding: 1052993
VCID: 1C376E06DFA1E2DE8D-8048
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 L HW: 4E0 907 279 L
Component: ILM Fahrer H12 0210
Coding: 0123123
Shop #: WSC 02313 785 00200
VCID: 3169AFB2A8237FB6CE-8064
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000035
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE7116580
Shop #: WSC 00000 000 00000
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 D HW: 4E0 035 593
Component: SDAR SIRIUS H04 0670
Revision: 00000000 Serial number: AUZ4Z7J0560331
VCID: 285F42D69BF93E7E19-807C
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0012141
VCID: 65C10BE2AC6BE316E2-8030
Component: Lenkradmodul H05 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 G HW: 4E0 920 950 G
Component: KOMBIINSTR. VDO H53 0210
Revision: D05 Serial number: AUDID3E1003831
Coding: 0016401
Shop #: WSC 22198 444 05017
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0040
Revision: 07 Serial number: 050050510928DC
Coding: FCFF7BDD1B7904
VCID: 26434CEE91ED280E2B-8072
11 Faults Found:
02003 - Driver Identification Control Module (J589)
01301 - Control Module for Voice Recognition (J507)
00778 - Steering Angle Sensor (G85)
004 - No Signal/Communication - Intermittent
01312 - Powertrain Data Bus
014 - Defective - Intermittent
00473 - Control Module for Elect. Park/Hand Brake (J540)
01321 - Control Module for Airbags (J234)
01771 - Control Module for Headlight Range (J431)
Address 1D: Driver Ident.
Cannot be reached
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
3 Faults Found:
Address 34: Level Control
Cannot be reached
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H08 0060
Coding: 4071530
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 F HW: 4E0 919 887 C
Component: MNS US H44 0990
Revision: 00000000 Serial number: 378BR057516308
4 Faults Found:
02261 - Data Medium
03183 - Data Media not Compatible
000 - - - Intermittent
02927 - DVD Read Error
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H02 0090
Serial number: 00000432400075
Coding: 0003477
VCID: 1D316302C4BBEBD67A-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM002 0060
Coding: 0032364
VCID: 204F5AF6F3C9C63E51-8074
1 Fault Found:
02126 - Central Locking Button; Exterior Door Handle
008 - Implausible Signal
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040501130070
Coding: 0064126
VCID: 275D41EA96E7310610-8072
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Subsystem 2 - Component: NGS keine Antwort
4 Faults Found:
02167 - Control Module for Tilt-Sensing Alarm (J529)
02107 - Trunk or Luggage Compartment Opening Motor (V254)
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 P HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0460
Revision: PROD_01 Serial number: 00000000011083
Coding: 0000016
VCID: 2A5BB8DE85F50C6E0F-807E
1 Fault Found:
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000054944
Coding: 0010111
VCID: 1E33640EC9BDF0CE63-804A
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Subsystem 2 - Serial number: VK4978T0MARE
2 Faults Found:
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM002 0060
Coding: 0032364
1 Fault Found:
02116 - Mirror Adjusting Motor
007 - Short to Ground - Intermittent
Address 53: Parking Brake
Cannot be reached
Address 55: Headlight Range
Cannot be reached
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 E
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 396BM057504153
Coding: 0000002
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0510
Revision: 00000000 Serial number: 00000000000958
Shop #: WSC 42286 444 85933
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 1502090082
Coding: 344530393135313035412056413031353032303930303832
Shop #: WSC 00000 128 00289
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM002 0060
Coding: 0032364
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01
Revision: 00010028 Serial number: 00000700030751
Coding: 0202125
VCID: 5FCD190A8E37B9C628-800A
2 Faults Found:
013 - Check DTC Memory
01477 - System Switched Off
000 - -
Address 67: Voice Control
Cannot be reached
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM002 0060
Coding: 0032364
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08720502700380
Coding: 0001208
VCID: 21495FF2F8C3CF365E-8074
4 Faults Found:
01626 - Sensor for Parking-Aid; Front Right (G252)
01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H10 1130
Revision: 00000000 Serial number: 00000007514144
Coding: 0010970
End-------------------------(Elapsed Time: 03:22)--------------------------
