info as per tag:
058 145 703 LX
K03/EF 92063 0438
Turbo is good, and can be used AS IS for a direct swap. Wastegate is also good, and is included.
(there is one exhaust bolt frozen within the exhaust side, nothing a little heat + penetrating oil + a drill tap cant get out)
zero in/out shaft play, and very minimal sideways play (does not touch the housing)
as with any used turbo I would recommend a rebuild kit and a good clean to ensure a long life.
I should be able to fit the turbo in a medium size flat rate box no problem, so,
$100 + $13.45 to ship anywhere within the US.
