We're pleased to announce the availability of the all-new Fluidampr 2.7T Engine Damper for the C5 Audi A6/allroad! These performance-engineered crankshaft pulleys are in stock and ready to ship.
Fluidampr 2.7T Engine Damper, B5 Audi S4/RS4 & C5 Audi A6/allroad
Retail: $449.00 + Shipping
We're excited to announce the availability of a proper engine damper for the Audi 2.7T engine from Fluidampr! The Fluidampr viscous torsional damper is an essential component in building a high performance 2.7T engine.
The last 2.7T to leave the assembly line in Germany was over 10 years ago, meaning factory dampers are old and tired. By now, an original 2.7T damper likely has hairline cracks in the rubber ring which is robbing your engine of horsepower as it is no longer adequately performing the job it was designed for. Couple the aged factory damper with increased strain on the motor through modifications, and you've got a recipe for disaster.
Benefits:
- Decreased Flywheel & Gearbox Chatter (Especially with the 01E Gearbox)
- RPM Drop Reduction
- Engine Vibration Reduction
- Sized for an OEM replacement at 162mm. Does not over-drive or under-drive the accessories.
- Steel construction with Black Zinc plating to combat oxidation from the elements, unlike the OEM unit.
- (6) equally spaced M8 x 1.25 threads on a 77mm bolt circle to allow additional accessory drives (dry sump , external wet sump pump drive , etc)
- Proudly Made in the U.S.A.
Fitment:
- 2000 - 2002 Audi S4 (B5)
- 2000 - 2002 Audi RS4 (B5)
- 1999 - 2004 Audi A6 2.7T (C5)
- 1999 - 2005 Audi allroad 2.7T (C5)
Protect your engine.
A Fluidampr performance damper provides premium, broad range control of destructive crankshaft torsional vibration for optimum performance and durability. Install when horsepower and rotating assembly parts change to reduce wear on critical internal engine components. Features high quality, long lasting viscous silicone technology with precision CNC machined and computer balanced high-grade steel components.
SFI 18.1 approved. Race proven for over 25 years. Made in USA. ISO 9001:2008 certified.
Please Note: We strongly recommend using new bolts when installing this part! It is critical to follow the factory torque procedure for the crankshaft bolts.
Please don't hesitate to contact us via PM or email if you have any questions.
Click Here to Order the Fluidampr 2.7T Crank Pulley!
You May Also Be Interested In:
034Motorsport 034Motorsport C5 Audi A6/allroad 2.7T Lightweight Single-Mass Flyhweel
034Motorsport C5 Audi A6/allroad 2.7T Performance Engine Mounts
