Results 1 to 10 of 10
    Jan 30 2016
    Philly
    Problem after pistons and rings were replaced
    I just had step 2 done last week and got my car back Saturday afternoon. I haven't even put 100 miles on it and I notice when I'm turning right like maybe an on ramp or exit ramp. It's like a thump thump thump at my feet like the axel is about to fall out. Its only when I turn right as of now. If I speed up,the thump speeds up. Im taking it back tomorrow before work. Thanks in advance
    Veteran Member Three Rings B44's Avatar
    Oct 27 2014
    is your car flashing the cel light? did you scan for any codes? this can be a drivetrain issue completely nothing to do with the piston replacement. perhaps a video of sort might better explain the situation than thump thump thump.
    Jan 30 2016
    Philly
    Quote Originally Posted by B44 View Post
    No light, no codes. Just seeing if anyone had a similar problem. Ill post when I get it checked by the dealer. Thank you tho.
    Feb 24 2013
    CA
    Engine mount?
    Senior Member Two Rings oshwi's Avatar
    Oct 07 2013
    nutley, nj
    or probably wheel bearings? i know those are a problem on early b8's
    2013 S5 Prestige
    STOCK. for now.....
    Gone: 2010 A4
    Mods: apikol rear diff mount / Zubehör rear diffuser / Unitronic HFC and DP / solo werks / awe boost gauge / carbonio APR intake
    Repairs done: Engine removed to complete repair Piston rings replaced (stage 1 and stage 2 oil consumption fix) / Wheel bearing(s)/hub(s) replaced / Crankshaft pulley/balancer replaced / Timing chain tensioner update
    Jan 30 2016
    Philly
    Turns out, my left front wheel had 3 lugs missing. They're covering the cost of the lugs but I feel like this is just ridiculous. Who knows what will go wrong next.
    Oct 07 2013
    nutley, nj
    what? they forgot to put 3 bolts on your wheels??
    2013 S5 Prestige
    STOCK. for now.....
    Gone: 2010 A4
    Jan 30 2016
    Philly
    Quote Originally Posted by oshwi View Post
    Im guessing they didn't tourqe them and they fell out. I called about the vibrations and he said bring it in. It got so bad on the way in im guessing more came out. Now I'm just worried about other damage
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    Quote Originally Posted by atrainbaby86 View Post
    That's scary. You are really luck the wheel didn't come off. That happened to a buddy of mine in high school and the wheel took out a parked motorcycle on the side of the road. Thankfully no one was on it. Shop had to cover the cost to repair the truck and replace the bike.
    A vibration like that could throw the whole car out of whack. Make them align it as well.
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Jan 30 2016
    Philly
    Quote Originally Posted by jmeenach View Post
    Yea, that's what I was thinking, I told them I wanted the wheel checked out, hub and check the alignment as well. I also want this stated on a document incase something happens in the future. Ya never know.
