I’m looking to do a bit of work on my 2006 Audi A4 2.0T FSI B7 in the next couple of weeks. I’d like to be sure I have everything I need prior to starting the project, specifically the tools to complete the project.
I’m looking to pull the cylinder head in order to replace the cam chain and cam chain tensioner along with changing out the timing belt w/ rollers tensioner etc, and replace the valve, head, cam, exhaust, & intake gasket along the way. I’d also like to swap out the fuel filter, snub mount and cam follower.
The tools I have at the moment are an assortment of standard mechanics tools, along with an M8 Triple square. I’m looking to pick up an MNXZ10, MN3452 and a T10252 cam locking tool.
The main reason for the project is that the belt was thrown off time about 2 months ago where the cam sprocket was about 1” ahead of time. There doesn’t seem to be any valve damage as I was able to get the engine back in time and was able to start it up without any issues. I’ve been babying it for the last month (about 750 miles so far) and would like to assure whatever caused the jump is fixed. I did have a P000A error code at about 650 miles, I didn’t notice any issues with the engine and cleared the code, and it has yet to return.
There is also a bit of noise coming from the engine which seems to match internet videos of a cam chain tensioner failure. I did notice the timing belt tensioner was about 1cm over tightened after the initial jump and the belt seemed lose enough to pull off the sprockets without even loosening the tensioner. After readjusting the belt seems to be tight, but I’d rather replace the whole timing system in order to assure there isn’t a bad part in there.
Any information would be greatly appreciated before I start in on this project. Thank you for any and all help.
